Up to 20% off select tools
Node Swap
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
53
All Time:
627
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Very easy
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Community-Contributed Guide
Node Swap
    1. Node Swap, Loosen front tapcon: step 1, image 1 of 2 Node Swap, Loosen front tapcon: step 1, image 2 of 2
      • the standard concrete drilled node
      • If your node is clamped or pole mounted skip to step 3
      Ask FixBot
    2. Node Swap, loosen back tapcon and swivel node toward you: step 2, image 1 of 1
      • with the front tapcon removed you should be able to swing the node back toward the concrete surface it's mounted on
      • you'll likely need to loosen the back tapcon and pull up on the cantilever for the node to pivot freely
      Ask FixBot
    3. Node Swap, remove old node: step 3, image 1 of 2 Node Swap, remove old node: step 3, image 2 of 2
      • first, note if the pin is weight bearing. if so make sure to support the node while you remove the pin (or lock)
      • pull old node out
      Ask FixBot
    4. Node Swap, replace with new node and measure: step 4, image 1 of 1
      • after sliding a new node in and replacing the pin or lock, measure the distance from the bottom of the ultrasonic depth sensor cone to the top of the cantilever beam. you may find a spare piece of strut to help with this.
      • you should do this before reattaching the front tapcon or clamp
      Ask FixBot
    5. Node Swap: step 5, image 1 of 2 Node Swap: step 5, image 2 of 2
      • Using a (weighted) tape measure, measure and record the distance from the bottom of the depth sensor node to the bottom of the river.
      • The bottom of the depth sensor node is defined as the bottom of the sensor cone.
      Ask FixBot
      • if node is drilled into concrete swivel the cantilever back to its full extent and reattach the front tapcon
      • if the node is clamped, reclamp the node at its full extent
      • for a pole-mounted node, you should be able to swap without altering the structure at all
      Ask FixBot
Finish Line
Author
with
Travis Dantzer
266 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 53
All Time: 627
