Tools
Spudger4.9
Introduction
Go to step 1 ↓If your tablet microphone is not working at its best, you can replace it easily using this guide. To do so, you will need to disassemble your tablet and use soldering tools.
Look towards the topside of the tablet, where the power button is located.
Insert a plastic opening tool in the crack between the two parts of the case.
Move it gently back and forth to open the case.
Locate the microphone's cables in front of the cameras' ZIF connector.
