Nobis NB07 Cameras Replacement
    1. Nobis NB07 Cameras Replacement, Opening the case: step 1, image 1 of 1
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Ask FixBot
    2. Nobis NB07 Cameras Replacement: step 2, image 1 of 3 Nobis NB07 Cameras Replacement: step 2, image 2 of 3 Nobis NB07 Cameras Replacement: step 2, image 3 of 3
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Ask FixBot
    3. Nobis NB07 Cameras Replacement, Replacing the battery: step 3, image 1 of 3 Nobis NB07 Cameras Replacement, Replacing the battery: step 3, image 2 of 3 Nobis NB07 Cameras Replacement, Replacing the battery: step 3, image 3 of 3
      • Remove the tape holding the battery in place.
      Ask FixBot
    4. Nobis NB07 Cameras Replacement: step 4, image 1 of 3 Nobis NB07 Cameras Replacement: step 4, image 2 of 3 Nobis NB07 Cameras Replacement: step 4, image 3 of 3
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Ask FixBot
    5. Nobis NB07 Cameras Replacement: step 5, image 1 of 1
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Ask FixBot
    6. Nobis NB07 Cameras Replacement: step 6, image 1 of 2 Nobis NB07 Cameras Replacement: step 6, image 2 of 2
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Ask FixBot
    1. Nobis NB07 Cameras Replacement, Removing the cameras: step 7, image 1 of 3 Nobis NB07 Cameras Replacement, Removing the cameras: step 7, image 2 of 3 Nobis NB07 Cameras Replacement, Removing the cameras: step 7, image 3 of 3
      • Remove the black tape covering the cameras power cable.
      Ask FixBot
    2. Nobis NB07 Cameras Replacement: step 8, image 1 of 2 Nobis NB07 Cameras Replacement: step 8, image 2 of 2
      • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
      Ask FixBot
    3. Nobis NB07 Cameras Replacement: step 9, image 1 of 3 Nobis NB07 Cameras Replacement: step 9, image 2 of 3 Nobis NB07 Cameras Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
      • Using tweezers, carefully grab the front camera and twist slowly.
      • The camera should release easily, do not twist too hard.
      • You can now remove the cameras.
      Ask FixBot
Daniel Gomero
966 Reputation
5 Guides authored
USF Tampa, Team 5-5, Brown Winter 2015 Member of USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 462
