Up to 20% off select tools
Nobis NB07 Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
94
All Time:
3,999
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
To complete this guide, you will need to disassemble your tablet and use a soldering iron to replace the battery. The battery is removed first in most cases, even if you are trying to remove other components.
    1. Nobis NB07 Battery Replacement, Opening the case: step 1, image 1 of 1
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      Ask FixBot
    2. Nobis NB07 Battery Replacement: step 2, image 1 of 3 Nobis NB07 Battery Replacement: step 2, image 2 of 3 Nobis NB07 Battery Replacement: step 2, image 3 of 3
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      Ask FixBot
    3. Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 1 of 3 Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 2 of 3 Nobis NB07 Battery Replacement, Replacing the battery: step 3, image 3 of 3
      • Remove the tape holding the battery in place.
      Ask FixBot
    4. Nobis NB07 Battery Replacement: step 4, image 1 of 3 Nobis NB07 Battery Replacement: step 4, image 2 of 3 Nobis NB07 Battery Replacement: step 4, image 3 of 3
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      Ask FixBot
    5. Nobis NB07 Battery Replacement: step 5, image 1 of 1
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      Ask FixBot
    6. Nobis NB07 Battery Replacement: step 6, image 1 of 2 Nobis NB07 Battery Replacement: step 6, image 2 of 2
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      Ask FixBot
3 other people completed this guide.
Author
with
Daniel Gomero
966 Reputation
5 Guides authored
USF Tampa, Team 5-5, Brown Winter 2015 Member of USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Members
60 Guides authored
1 Guide Comment
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 94
All Time: 3,999
