Nixon Mission Android Wear Motherboard Replacement
  1. Nixon Mission Android Wear Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Unscrew 4 4.5mm Phillips head screws from the back of the device.
    Ask FixBot
  2. Nixon Mission Android Wear Motherboard Replacement: step 2, image 1 of 1
    • Remove back.
    Ask FixBot
  3. Nixon Mission Android Wear Motherboard Replacement: step 3, image 1 of 1
    • Unclip straps holding motherboard to screen using a spudger.
    Ask FixBot
  4. Nixon Mission Android Wear Motherboard Replacement: step 4, image 1 of 1
    • Unscrew 2 3.0mm Phillips head screws holding motherboard in place.
    • The other screw is hidden under the copper band on opposite side.
    Ask FixBot
  5. Nixon Mission Android Wear Motherboard Replacement: step 5, image 1 of 1
    • Remove the "core" of the device from case.
    Ask FixBot
  6. Nixon Mission Android Wear Motherboard Replacement: step 6, image 1 of 2 Nixon Mission Android Wear Motherboard Replacement: step 6, image 2 of 2
    • Separate motherboard from screen and then clean or replace motherboard.
    Ask FixBot
Spencer Kolzow
179 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2017 Member of IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Members
3 Guides authored
2 Guide Comments
Hello… where can i get the replacement motherboard???
Juan Pablo Balderrama - Reply Share
Is it still waterproof after you open it?
Smarty - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,040
