Up to 20% off select tools
Nixon Mission Android Wear Front Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
92
All Time:
1,408
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nixon Mission Android Wear Front Screen  Replacement, Front Screen: step 1, image 1 of 1
      • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
      Ask FixBot
    2. Nixon Mission Android Wear Front Screen  Replacement: step 2, image 1 of 1
      • Remove the back plate of watch.
      Ask FixBot
    3. Nixon Mission Android Wear Front Screen  Replacement: step 3, image 1 of 1
      • Unclip 5 latches from motherboard using a spudger.
      Ask FixBot
    4. Nixon Mission Android Wear Front Screen  Replacement: step 4, image 1 of 1
      • Remove 2 3.0mm Phillips screws from motherboard using PH00 Phillips head.
      Ask FixBot
    5. Nixon Mission Android Wear Front Screen  Replacement: step 5, image 1 of 1
      • Carefully remove motherboard & internal screen.
      Ask FixBot
    6. Nixon Mission Android Wear Front Screen  Replacement: step 6, image 1 of 1
      • Remove 4 7.0mm hex-screws from front of watch using H1.5 Hex head.
      Ask FixBot
    7. Nixon Mission Android Wear Front Screen  Replacement: step 7, image 1 of 1
      • Remove outer screen frame from front of watch.
      Ask FixBot
    8. Nixon Mission Android Wear Front Screen  Replacement: step 8, image 1 of 1
      • Remove 4 4.5mm Phillips gold screws from back of watch using PH00 Phillips head.
      Ask FixBot
    9. Nixon Mission Android Wear Front Screen  Replacement: step 9, image 1 of 1
      • Remove outer protective screen.
      • Replace outer protective screen with the new part.
      Ask FixBot
Author
with
Venkata
113 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2017 Member of IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 Members
36 Guides authored
2 Guide Comments
But can you even buy replacement screen
Josh Leaney - Reply Share
Where can you buy a replacement screen?
Ethan Whitton - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 92
All Time: 1,408
