Niu Kqi3 Max Tire Replacement
  1. Niu Kqi3 Max Tire Replacement, Tire: step 1, image 1 of 2 Niu Kqi3 Max Tire Replacement, Tire: step 1, image 2 of 2
    • Use a floor jack or center stand to lift the scooter, making it easier to remove the tire.
    • Remove the sticker that covers the the Mortorq drive screw under it.
    Ask FixBot
  2. Niu Kqi3 Max Tire Replacement: step 2, image 1 of 3 Niu Kqi3 Max Tire Replacement: step 2, image 2 of 3 Niu Kqi3 Max Tire Replacement: step 2, image 3 of 3
    • Use the pliers to remove the cotter pin and loosen the nut securing the rear wheel to the axle.
    • Use the tire lever to pry the tire off the rim of the wheel.
    Ask FixBot
  3. Niu Kqi3 Max Tire Replacement: step 3, image 1 of 3 Niu Kqi3 Max Tire Replacement: step 3, image 2 of 3 Niu Kqi3 Max Tire Replacement: step 3, image 3 of 3
    • Remove the inner tube from the tire and rim.
    • Detach the connectors so you're able to completely remove the tire.
    Ask FixBot
  4. Niu Kqi3 Max Tire Replacement: step 4, image 1 of 3 Niu Kqi3 Max Tire Replacement: step 4, image 2 of 3 Niu Kqi3 Max Tire Replacement: step 4, image 3 of 3
    • Insert the new inner tube into the tire and align it with the rim. Use the tire lever to carefully fit the tire back onto the rim of the wheel.
    Ask FixBot
  5. Niu Kqi3 Max Tire Replacement: step 5, image 1 of 2 Niu Kqi3 Max Tire Replacement: step 5, image 2 of 2
    • Reattach the nut and secure it with the cotter pin. Slide the rear wheel back into the scooter frame and reattach the axle bolt.
    Ask FixBot
  6. Niu Kqi3 Max Tire Replacement: step 6, image 1 of 2 Niu Kqi3 Max Tire Replacement: step 6, image 2 of 2
    • Lower the scooter and inflate the tire.
    Ask FixBot
Replacing a tire on a Niu Kqi3 Max scooter is not a difficult task, but it does require a few tools and some basic mechanical skills. With the help of this guide, you can successfully replace the tire on your scooter and get it back on the road quickly and safely.
2 other people completed this guide.
Redamsri0
181 Reputation
1 Guide authored
4 Guide Comments
Hey there! Where did you find the spare inner tube? I can’t seem to find it anywhere online... Thanks!
Beeson - Reply Share
Yout brake calipers are not the red ones that are on my max, did you change them out with other ones?
Joshuaesp - Reply Share
Hi we are looking for tire replacements
Char - Reply Share
it looks like the descriptions do not match the pictures or actual repair. for example the kqi series of scooters do not use innertubes. they are tubeless pneumatic tires (similar to on a standard car)
also the images show disconnecting of the battery pack (and thus having removed the deck of the scooter) but nowhere is the description does it say to do that
Gary Cosby (Da Coz) - Reply Share
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 202
All Time: 6,577
