Up to 20% off select tools
Nissan Versa Note Media Display System Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
47
Past 30 Days:
184
All Time:
7,190
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you’d like to replace your Nissan Versa Note’s media/navigation/radio system, this guide will show you the removal process. Ensure that your car’s engine and battery (accessory mode) are off before trying the replacement. If you plan on discarding the media system, you should locate your local recycling center as this device should not be simply thrown into the garbage.
    1. Nissan Versa Note Media Display System Replacement, Media Display System: step 1, image 1 of 1
      • Ensure that the car is turned off.
      Ask FixBot
    2. Nissan Versa Note Media Display System Replacement: step 2, image 1 of 1
      • Pull on the switch for indoor/outdoor air to remove it.
      Ask FixBot
    3. Nissan Versa Note Media Display System Replacement: step 3, image 1 of 2 Nissan Versa Note Media Display System Replacement: step 3, image 2 of 2
      • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
      • After wedging the parts apart you will see a gap.
      Ask FixBot
    4. Nissan Versa Note Media Display System Replacement: step 4, image 1 of 3 Nissan Versa Note Media Display System Replacement: step 4, image 2 of 3 Nissan Versa Note Media Display System Replacement: step 4, image 3 of 3
      • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
      Ask FixBot
    5. Nissan Versa Note Media Display System Replacement: step 5, image 1 of 2 Nissan Versa Note Media Display System Replacement: step 5, image 2 of 2
      • Once the panel is free from the dash, flip it over to expose the cables connected to it.
      Ask FixBot
    6. Nissan Versa Note Media Display System Replacement: step 6, image 1 of 3 Nissan Versa Note Media Display System Replacement: step 6, image 2 of 3 Nissan Versa Note Media Display System Replacement: step 6, image 3 of 3
      • Remove the top cable by simply squeezing the end and pulling it out of its socket.
      • Use a spudger to push down on the tab of the bottom cable and remove it.
      Ask FixBot
    7. Nissan Versa Note Media Display System Replacement: step 7, image 1 of 3 Nissan Versa Note Media Display System Replacement: step 7, image 2 of 3 Nissan Versa Note Media Display System Replacement: step 7, image 3 of 3
      • The front panel is now completely free from the dash and can be set aside.
      • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
      Ask FixBot
    8. Nissan Versa Note Media Display System Replacement: step 8, image 1 of 2 Nissan Versa Note Media Display System Replacement: step 8, image 2 of 2
      • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
      • Use your hands to pinch the tabs and gently pull out each cable.
      Ask FixBot
    9. Nissan Versa Note Media Display System Replacement: step 9, image 1 of 3 Nissan Versa Note Media Display System Replacement: step 9, image 2 of 3 Nissan Versa Note Media Display System Replacement: step 9, image 3 of 3
      • Now the media system is completely free from the car.
      • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
      Ask FixBot
3 other people completed this guide.
Author
with
Matthew do Santos-Zounon
238 Reputation
1 Guide authored
1 Guide Comment
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - Reply Share
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 184
All Time: 7,190
