Nissan Leaf Key Fob Battery Replacement
View statistics:
Past 24 Hours:
9
Past 7 Days:
44
Past 30 Days:
128
All Time:
128
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The Nissan Leaf key fob uses 2025 or 2032 batteries.
In my experience, the 2032 batteries tend to last around 3 years.
Parts
Tools
    1. Nissan Leaf Key Fob Battery Replacement, Remove key from fob housing: step 1, image 1 of 2 Nissan Leaf Key Fob Battery Replacement, Remove key from fob housing: step 1, image 2 of 2
      • With the buttons facing up, turn the key over
      • The small switch needs to be pulled back and held to allow the manual key to be removed
      Ask FixBot
    2. Nissan Leaf Key Fob Battery Replacement, Split the fob housing: step 2, image 1 of 1
      • Partly insert the key in the housing, twist to split the housing
      • Insert the ifixit spudger into the seam
      • Run the spudger around the seam, continue twisting the key to help with splitting the fob open
      Ask FixBot
      • Use the spudger to get the old battery out
      Ask FixBot
      • The 2025 / 2032 coin cell batteries have one face that is larger than the other - this will be the positive. It should also be marked.
      • Insert the coin into the recess with the positive side FACE DOWN.
      • Re-assemble the key fob by pressing the two parts together - there should be a positive snapping sound.
      Ask FixBot
Chris
452 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 44
Past 30 Days: 128
All Time: 128
