Nissan Altima 2015 Brake Light Bulb Replacement
  1. Nissan Altima 2015 Brake Light Bulb Replacement, Brake Light Bulb: step 1, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement, Brake Light Bulb: step 1, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement, Brake Light Bulb: step 1, image 3 of 3
    • Open the trunk and locate the rear brake light housing on the side where the bulb is burnt out.
    • The brake light assembly is usually held in place by a few screws or clips that you’ll remove in the next step.
    Ask FixBot
  2. Nissan Altima 2015 Brake Light Bulb Replacement: step 2, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 2, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 2, image 3 of 3
    • Use a trim remover tool to remove the interior trunk panel clips that cover the back of the taillight assembly.
    • Be gentle when prying up the clips—plastic trim pieces can crack if too much force is used.
    • Set the clips aside to use for reassembly.
    • Carefully peel back the trunk lining from the area you will be working.
    Ask FixBot
  3. Nissan Altima 2015 Brake Light Bulb Replacement: step 3, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 3, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 3, image 3 of 3
    • Use an 8 mm wrench to remove the screws (or unclip the fasteners) securing the brake light housing.
    • Keep the screws or clips in a small container so they don’t get lost.
    Ask FixBot
  4. Nissan Altima 2015 Brake Light Bulb Replacement: step 4, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 4, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 4, image 3 of 3
    • Carefully pull the entire tail light housing straight back from the car.
    • Wiggle it slightly if it feels stuck.
    • It should pop free without excessive force.
    • Don’t pull too far—wiring for the bulb sockets is still connected.
    Ask FixBot
  5. Nissan Altima 2015 Brake Light Bulb Replacement: step 5, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 5, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 5, image 3 of 3
    • Twist the bulb socket counterclockwise to unlock it.
    • Pull it out of the housing.
    • It may take a gentle turn to release—don’t force it.
    Ask FixBot
  6. Nissan Altima 2015 Brake Light Bulb Replacement: step 6, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 6, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 6, image 3 of 3
    • Pull the old bulb straight out of the socket.
    • Insert a new 7443 dual-filament bulb firmly into the socket until it clicks into place.
    • Avoid touching the glass of the bulb, as oils and salts from your hands can create hot spots and cause it to burn out more quickly.
    Ask FixBot
  7. Nissan Altima 2015 Brake Light Bulb Replacement: step 7, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 7, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 7, image 3 of 3
    • Reinsert the bulb socket into the housing and twist clockwise to lock it.
    • Align the tail light housing with the car body and push it back into place.
    • Secure it with the screws or clips you removed earlier.
    • Double-check that all clips are firmly seated and the housing sits flush with the car body.
    Ask FixBot
  8. Nissan Altima 2015 Brake Light Bulb Replacement: step 8, image 1 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 8, image 2 of 3 Nissan Altima 2015 Brake Light Bulb Replacement: step 8, image 3 of 3
    • Start the car or turn the ignition key to “On.”
    • Press the brake pedal (or ask someone to help) and check that the new light illuminates properly.
    • If the light doesn’t work, make sure the bulb is seated correctly and the socket is fully connected.
    Ask FixBot
To reassemble your car, simply follow the previous steps in reverse order, ensuring each component is securely reattached. Before finishing up, take a moment to test your brake lights to confirm everything is working properly.
Brett Younger
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 67
All Time: 420
