Nissan 350Z Tail Light Replacement
  1. Nissan 350Z Tail Light Replacement, Nissan 350Z Tail Light: step 1, image 1 of 1
    • Unlock and open the trunk.
    • The button is located right above your license plate.
    Ask FixBot
  2. Nissan 350Z Tail Light Replacement: step 2, image 1 of 2 Nissan 350Z Tail Light Replacement: step 2, image 2 of 2
    • Look for the 3 bolts that secure the tail light to the car.
    • Attach your 10MM socket to your 1/4 inch ratchet.
    Ask FixBot
  3. Nissan 350Z Tail Light Replacement: step 3, image 1 of 2 Nissan 350Z Tail Light Replacement: step 3, image 2 of 2
    • Using your 10MM socket and 1/4 inch ratchet remove the three bolts.
    • Make sure to keep the bolts together and in a safe place.
    Ask FixBot
  4. Nissan 350Z Tail Light Replacement: step 4, image 1 of 1
    • Hold both ends of the headlight and carefully remove the assembly.
    • You may need to use some force when pulling, as dowel pins secure it to the car.
    • You can flip the tail light over and place it in the tail light cavity so you do not have to hold it.
    Ask FixBot
  5. Nissan 350Z Tail Light Replacement: step 5, image 1 of 3 Nissan 350Z Tail Light Replacement: step 5, image 2 of 3 Nissan 350Z Tail Light Replacement: step 5, image 3 of 3
    • Check the underside of the connector for a square-shaped slot.
    • Insert your flathead screwdriver into the square tab to disconnect the connector.
    • If you are having trouble with this part, try to push the tab in then down.
    Ask FixBot
  6. Nissan 350Z Tail Light Replacement: step 6, image 1 of 2 Nissan 350Z Tail Light Replacement: step 6, image 2 of 2
    • Reconnect the tail light cable connector to the new tail light assembly.
    • Press the connector firmly into the socket to ensure a secure connection.
    Ask FixBot
  7. Nissan 350Z Tail Light Replacement: step 7, image 1 of 1
    • Align the dowel pins to allow the light assembly to seat itself safely.
    Ask FixBot
  8. Nissan 350Z Tail Light Replacement: step 8, image 1 of 2 Nissan 350Z Tail Light Replacement: step 8, image 2 of 2
    • Replace the bolts and use your hand to tighten the bolt just a bit.
    • Use a ratchet with the 10 mm socket to tighten the bolts fully.
    • Avoid overtightening the bolts, as this can make it harder to remove them the next time you need to replace the tail light.
    Ask FixBot
sddale
157 Reputation
1 Guide authored
UC Davis, Team 3-7, Whithaus Spring 2025 Member of UC Davis, Team 3-7, Whithaus Spring 2025
UCD-WHITHAUS-S25S3G7
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 407
