Nintendo Wii mini Fan Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
98
All Time:
2,188
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to replace the fan in your Nintendo Wii mini in the case of it malfunctioning or failing to work. If your fan does break, it is important to replace it as soon as possible to prevent your system from overheating, which can lead to further damage. The importance of this part also helps prolong the usage/life of the other internal components, keeping the replacement rate down.
Once you have successfully replaced your fan, run the system to confirm the fan works and prevents overheating.
Parts
Tools
    1. Nintendo Wii mini Fan Replacement, Unscrew the Bottom: step 1, image 1 of 2 Nintendo Wii mini Fan Replacement, Unscrew the Bottom: step 1, image 2 of 2
      • Remove the two rubber feet at the back of the console to reveal the hidden screws.
      • Remove the four 6mm Phillips #0 screws.
      Ask FixBot
    2. Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 1 of 3 Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 2 of 3 Nintendo Wii mini Fan Replacement, Remove the Cover: step 2, image 3 of 3
      • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
      • Gently lift the top piece of the console and set it aside.
      Ask FixBot
    1. Nintendo Wii mini Fan Replacement, Unscrew the Fan: step 3, image 1 of 2 Nintendo Wii mini Fan Replacement, Unscrew the Fan: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Turn the Wii mini around so that the back of the device is facing you.
      • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
      • You may need to use tweezers to pull out the screws once they are loosened.
      Ask FixBot
    2. Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 1 of 3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 2 of 3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: step 4, image 3 of 3
      • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
      • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
      • Remove the fan piece and set it aside.
      Ask FixBot
3 other people completed this guide.
Kristin Anderson
1,029 Reputation
5 Guides authored
UWT Liner: Group 5 Member of UWT Liner: Group 5
Community
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 98
All Time: 2,188
