Nintendo Wii mini Disc Drive Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
136
All Time:
6,473
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will provide instruction on replacing the disc drive in your Nintendo Wii mini so game discs can be inserted. Aside from the disc drive being incapable of taking in a disc, other reasons are dirt on the disc and scratches that can ultimately make the game choppy/appear unclear. You may need to replace the disc. The troubleshooting page will give you more insight on further issues.
Using tweezers to handle small objects such as screws are suggested to prevent the loss of contents. To prevent further issues regarding hardware, do not tamper with connector or cables while detaching the fan, for it may cause the connector to loosen.
Parts
Tools
    1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: step 1, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: step 1, image 2 of 2
      • Remove the two rubber feet at the back of the console to reveal the hidden screws.
      • Remove the four 6mm Phillips #0 screws.
      Ask FixBot
    2. Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: step 2, image 3 of 3
      • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
      • Gently lift the top piece of the console and set it aside.
      Ask FixBot
    1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: step 3, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Turn the Wii mini around so that the back of the device is facing you.
      • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
      • You may need to use tweezers to pull out the screws once they are loosened.
      Ask FixBot
    2. Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: step 4, image 3 of 3
      • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
      • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
      • Remove the fan piece and set it aside.
      Ask FixBot
    1. Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 1 of 3 Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 2 of 3 Nintendo Wii mini Disc Drive Replacement, Power Board: step 5, image 3 of 3
      • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
      • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
      Ask FixBot
    2. Nintendo Wii mini Disc Drive Replacement: step 6, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 6, image 2 of 2
      • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
      Ask FixBot
    3. Nintendo Wii mini Disc Drive Replacement: step 7, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 7, image 2 of 2
      • Lift the power board from the console and set it aside.
      Ask FixBot
    1. Nintendo Wii mini Disc Drive Replacement, Disc Drive: step 8, image 1 of 2 Nintendo Wii mini Disc Drive Replacement, Disc Drive: step 8, image 2 of 2
      • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
      Ask FixBot
    2. Nintendo Wii mini Disc Drive Replacement: step 9, image 1 of 2 Nintendo Wii mini Disc Drive Replacement: step 9, image 2 of 2
      • Lift the disc drive out of the console and set it aside.
      Ask FixBot
4 other people completed this guide.
Kristin Anderson
1,029 Reputation
5 Guides authored
UWT Liner: Group 5 Member of UWT Liner: Group 5
Community
3 Members
60 Guides authored
1 Guide Comment
i even took apart the disk drive. turns out it wasn't working because the lid was missing one of the plastic parts that pushes the sensor in the disk drive that indicates that the lid is closed
Alexander Busse - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 136
All Time: 6,473
