Nintendo Wii U Front Faceplate Replacement
    1. Nintendo Wii U Front Faceplate Replacement, Console Outer Case: step 1, image 1 of 1
      • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
      • Three 5.1mm Phillips #000 screws
      • Two 6.1mm Tri-wing Y0 screws
      • One 13.2mm Tri-wing Y1 screw
      Ask FixBot
    2. Nintendo Wii U Front Faceplate Replacement: step 2, image 1 of 1
      • Rotate the console 180 degrees so that the exhaust vents are facing you.
      • Remove the two 7.1mm Phillips #00 screws.
      Ask FixBot
    3. Nintendo Wii U Front Faceplate Replacement: step 3, image 1 of 2 Nintendo Wii U Front Faceplate Replacement: step 3, image 2 of 2
      • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
      Ask FixBot
    4. Nintendo Wii U Front Faceplate Replacement: step 4, image 1 of 1
      • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
      Ask FixBot
    5. Nintendo Wii U Front Faceplate Replacement: step 5, image 1 of 3 Nintendo Wii U Front Faceplate Replacement: step 5, image 2 of 3 Nintendo Wii U Front Faceplate Replacement: step 5, image 3 of 3
      • On the back of the console, lift up and release the main top cover.
      Ask FixBot
    1. Nintendo Wii U Front Faceplate Replacement, Front Faceplate: step 6, image 1 of 2 Nintendo Wii U Front Faceplate Replacement, Front Faceplate: step 6, image 2 of 2
      • Rotate the device so that the front plate is facing you.
      • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
      Ask FixBot
    2. Nintendo Wii U Front Faceplate Replacement: step 7, image 1 of 1
      • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
      • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
      • Lift up on the blue tab to release the ribbon cable.
      Ask FixBot
    3. Nintendo Wii U Front Faceplate Replacement: step 8, image 1 of 1
      • Remove the front faceplate.
      Ask FixBot
11 other people completed this guide.
Kim Arre
5,763 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
96 Guides authored
4 Guide Comments
Great guide. I was able to fix the front USB door on my Wii u! Thanks guys!
Matt Jones - Reply Share
My ribbon seems to work but the little connection it plugs into on the circuit board in the console broke off. Not just the black clip but the whole little circuit. Seems like a clean break. Can I solder it back on? If I push it back on and hold the ribbon in the red light comes on and blinks. Occasionally I can get the white light to come on for like a second but I never hear fans spinning/more of the unit coming to life before it shuts itself off.
Thoughts on how to fix it?
Gutzin Fish - Reply Share
My daughter shoved change into my disc slot of my Wii I. I thought I got out all pulling through the faceplate dvd slot but now when I put in a game disc it won’t catcalls accept it. It pulls in, sounds like it turns a little bit and then ejects the disc. Could change still be stuck in the reader or do I need to replace it now?
Melissa - Reply Share
Bit sad that it doesn't show how to re-insert the little ribbon cable. The tiny black latch came off, and there's no way to refix the latch back to the connector.
Regards,
Adrie
Adrie Lute - Reply Share
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 142
All Time: 15,642
