Nintendo Wii U Button Replacement
Views: 7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
150
All Time:
6,959
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this replacement guide for step-by-step instruction on how to replace the power and accompanying buttons on the Wii U console's front face panel.
Tools
    1. Nintendo Wii U Button Replacement, Button Replacement: step 1, image 1 of 2 Nintendo Wii U Button Replacement, Button Replacement: step 1, image 2 of 2
      • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
      • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
      Ask FixBot
    2. Nintendo Wii U Button Replacement: step 2, image 1 of 1
      • Remove the five Phillips #0 screws.
      • Remove the four Tri-Wing Y1 screws.
      Ask FixBot
    3. Nintendo Wii U Button Replacement: step 3, image 1 of 2 Nintendo Wii U Button Replacement: step 3, image 2 of 2
      • Remove the CMOS battery door on the left side of the console.
      • Once the door is removed, remove the three Phillips #0 screws.
      Ask FixBot
    4. Nintendo Wii U Button Replacement: step 4, image 1 of 3 Nintendo Wii U Button Replacement: step 4, image 2 of 3 Nintendo Wii U Button Replacement: step 4, image 3 of 3
      • Gently pry off the top lid of the Wii U.
      Ask FixBot
    5. Nintendo Wii U Button Replacement: step 5, image 1 of 3 Nintendo Wii U Button Replacement: step 5, image 2 of 3 Nintendo Wii U Button Replacement: step 5, image 3 of 3
      • Rotate the device so that the front plate is facing you.
      • Remove the two Phillips #1 screws.
      Ask FixBot
    6. Nintendo Wii U Button Replacement: step 6, image 1 of 3 Nintendo Wii U Button Replacement: step 6, image 2 of 3 Nintendo Wii U Button Replacement: step 6, image 3 of 3
      • Remove the ribbon cable and separate the front plate from the main console.
      Ask FixBot
    7. Nintendo Wii U Button Replacement: step 7, image 1 of 1
      • Remove the three Phillips #1 screws.
      Ask FixBot
    8. Nintendo Wii U Button Replacement: step 8, image 1 of 1
      • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
      Ask FixBot
    9. Nintendo Wii U Button Replacement: step 9, image 1 of 1
      • Remove the desired button(s).
      Ask FixBot
Emily Vasquez
1,058 Reputation
3 Guides authored
USF Tampa, Team 1-2, Leahy Spring 2016 Member of USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Members
48 Guides authored
1 Guide Comment
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 150
All Time: 6,959
