Nintendo Wii Remote Motherboard Replacement
Views: 42K
View statistics:
Past 24 Hours:
12
Past 7 Days:
98
Past 30 Days:
387
All Time:
41,558
Comments: 10
3 comments on steps, 7 guide comments.
Go to guide comments
Completed: 37
37 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
Tools
    1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
      Ask FixBot
    2. Nintendo Wii Remote Motherboard Replacement: step 2, image 1 of 1
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
      Ask FixBot
    3. Nintendo Wii Remote Motherboard Replacement: step 3, image 1 of 1
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
      Ask FixBot
    4. Nintendo Wii Remote Motherboard Replacement: step 4, image 1 of 2 Nintendo Wii Remote Motherboard Replacement: step 4, image 2 of 2
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
      Ask FixBot
    1. Nintendo Wii Remote Motherboard Replacement, Motherboard: step 5, image 1 of 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Using the connector port, gently lift the motherboard about 2 cm from the base.
      • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
      Ask FixBot
    2. Nintendo Wii Remote Motherboard Replacement: step 6, image 1 of 2 Nintendo Wii Remote Motherboard Replacement: step 6, image 2 of 2
      • Grasp the edges of the motherboard and pull it straight away from the case.
      Ask FixBot
37 other people completed this guide.
Emily
2,030 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
72 Guides authored
7 Guide Comments
Where do you find a motherboard and how much do they typically cost?
Jeff - Reply Share
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Reply Share
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign - Reply Share
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Reply Share
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Reply Share
Past 24 Hours: 12
Past 7 Days: 98
Past 30 Days: 387
All Time: 41,558
