Up to 20% off select tools
Nintendo Wii Remote Main Buttons Replacement
Views: 51K
View statistics:
Past 24 Hours:
12
Past 7 Days:
91
Past 30 Days:
411
All Time:
51,118
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Removing the main buttons requires opening the device. The main buttons include all buttons except the trigger style B button.
    1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
      • Flip the Wii Remote over so the battery cover faces you.
      • Push up on the bottom tab.
      • Remove the battery cover.
      Ask FixBot
    2. Nintendo Wii Remote Main Buttons Replacement: step 2, image 1 of 1
      • Remove the first battery by pressing down on the positive end and pulling the battery out.
      • Remove the second battery by pushing up on the positive end and pulling the battery out.
      Ask FixBot
    3. Nintendo Wii Remote Main Buttons Replacement: step 3, image 1 of 1
      • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
      • Repeat with the two bottom screws.
      Ask FixBot
    4. Nintendo Wii Remote Main Buttons Replacement: step 4, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement: step 4, image 2 of 2
      • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
      • These tabs are breakable. However, if the tabs are broken the controller will still function.
      • Open the front plate like a book.
      • Small parts may fall out as you open the front plate.
      Ask FixBot
    1. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 1 of 2 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: step 5, image 2 of 2
      • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
      Ask FixBot
    2. Nintendo Wii Remote Main Buttons Replacement: step 6, image 1 of 1
      • Flip over the cover, allowing the buttons to fall into your hand.
      • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
      • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
      • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
      Ask FixBot
27 other people completed this guide.
Author
with
Emily
2,042 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
72 Guides authored
5 Guide Comments
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Reply Share
Me too, can’t find them.
Michael Velten - Reply Share
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Reply Share
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - Reply Share
Yo tampoco los encuentro por ninguna parte
kinoto taller - Reply Share
Past 24 Hours: 12
Past 7 Days: 91
Past 30 Days: 411
All Time: 51,118
