Nintendo Wii Nunchuk Control Stick Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
39
Past 30 Days:
185
All Time:
3,752
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Nintendo Wii Nunchuk control stick is an important component that can develop issues over time, preventing it from working correctly. These issues can result in the stick drifting or not working at all. This guide will help you learn how to replace the control stick by taking apart the Nunchuk to fix any issues with the component. Taking apart the Nunchuk is a useful skill that can be used for other repairs of the Nunchuk in the future, as well as diagnosing any other potential issues with the Nunchuk.
This guide does not require any previous experience with repairs, and only requires the use of a Triwing Y0-Point screwdriver, as well as either a Gameboy control stick or a Nunchuk control stick to replace the original component. It is a relatively quick repair to ensure that you could get back to your gaming as quickly and smoothly as possible.
    1. Nintendo Wii Nunchuk Control Stick Replacement, Control Stick: step 1, image 1 of 1
      • Clean and disinfect the Nintendo Nunchuk with disinfectant wipes to remove any bacteria, dust, or stains.
      Ask FixBot
    2. Nintendo Wii Nunchuk Control Stick Replacement: step 2, image 1 of 2 Nintendo Wii Nunchuk Control Stick Replacement: step 2, image 2 of 2
      Ask FixBot
    3. Nintendo Wii Nunchuk Control Stick Replacement: step 3, image 1 of 1
      • Remove the top cover of the Nunchuk by pulling it off with your fingers.
      • Be careful not to pull too hard on the cover so that you do not accidently dislodge the parts inside the Nunchuk. You may need to apply some more force if your Nunchuk is an older model.
      Ask FixBot
    4. Nintendo Wii Nunchuk Control Stick Replacement: step 4, image 1 of 1
      • Remove the central control stick by tugging on it until the control stick slides off the slot.
      • You may need to pull harder on the control stick if your Nunchuk is an older device.
      Ask FixBot
    5. Nintendo Wii Nunchuk Control Stick Replacement: step 5, image 1 of 1
      • Attach the new stick by inserting either the Nintendo Wii Nunchuk Control Stick or a Gameboy Controller Control Stick onto the nub.
      • Make sure that the stick is securely and firmly inserted.
      Ask FixBot
2 other people completed this guide.
Sky Ye
175 Reputation
1 Guide authored
2 Guide Comments
Cómo reparar el botón del control de wii que queda dentro y no sale ni gunciona
Fredy rosado - Reply Share
Dans le cas de la Wiimote ou du Nunchuk, il sera nécessaire d'ouvrir le boîtier pour voir ce qui provoque ce problème. Pour nettoyer, utilisez un coton tige et de l'alcool isopropylique.
AreUBready - Reply Share
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 185
All Time: 3,752
