Nintendo Wii Heat Sink Replacement
    1. Nintendo Wii Heat Sink Replacement, Faceplate: step 1, image 1 of 2 Nintendo Wii Heat Sink Replacement, Faceplate: step 1, image 2 of 2
      • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
      Ask FixBot
    2. Nintendo Wii Heat Sink Replacement: step 2, image 1 of 1
      • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
      Ask FixBot
    3. Nintendo Wii Heat Sink Replacement: step 3, image 1 of 1
      • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
      Ask FixBot
    4. Nintendo Wii Heat Sink Replacement: step 4, image 1 of 1
      • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
      Ask FixBot
    5. Nintendo Wii Heat Sink Replacement: step 5, image 1 of 1
      • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
      Ask FixBot
    6. Nintendo Wii Heat Sink Replacement: step 6, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully pull the faceplate away from the front of the Wii.
      • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
      • Remove the faceplate.
      Ask FixBot
    1. Nintendo Wii Heat Sink Replacement, Outer Case: step 7, image 1 of 3 Nintendo Wii Heat Sink Replacement, Outer Case: step 7, image 2 of 3 Nintendo Wii Heat Sink Replacement, Outer Case: step 7, image 3 of 3
      • Open the controller port cover until it is perpendicular to the black controller port bezel.
      • Pull the controller port cover straight up to release it from the outer case.
      • Repeat this procedure for the memory card port cover.
      Ask FixBot
    2. Nintendo Wii Heat Sink Replacement: step 8, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 8, image 2 of 2
      • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
      • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
      Ask FixBot
    3. Nintendo Wii Heat Sink Replacement: step 9, image 1 of 1
      • Remove the two 5 mm Phillips screws above the controller ports.
      Ask FixBot
    4. Nintendo Wii Heat Sink Replacement: step 10, image 1 of 1
      • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
      Ask FixBot
    5. Nintendo Wii Heat Sink Replacement: step 11, image 1 of 1
      • Remove the following screws:
      • Two 5 mm Phillips screws
      • One 8.2 mm Tri-Point screw
      Ask FixBot
    6. Nintendo Wii Heat Sink Replacement: step 12, image 1 of 1
      • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
      Ask FixBot
    7. Nintendo Wii Heat Sink Replacement: step 13, image 1 of 1
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      Buy
      • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
      • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
      Ask FixBot
    8. Nintendo Wii Heat Sink Replacement: step 14, image 1 of 1
      • Lift the outer case straight up off the body of the Wii.
      Ask FixBot
    1. Nintendo Wii Heat Sink Replacement, DVD Drive: step 15, image 1 of 2 Nintendo Wii Heat Sink Replacement, DVD Drive: step 15, image 2 of 2
      • Remove the small Phillips screw securing the battery door to the bottom panel.
      • This screw is captive to the battery door.
      • Pull the battery door out of the Wii.
      • The system time will be reset once you remove the battery door.
      • This is a good time to change the CR2032 battery if it hasn't been changed recently.
      Ask FixBot
    2. Nintendo Wii Heat Sink Replacement: step 16, image 1 of 1
      • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
      Ask FixBot
    3. Nintendo Wii Heat Sink Replacement: step 17, image 1 of 1
      • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
      Ask FixBot
    4. Nintendo Wii Heat Sink Replacement: step 18, image 1 of 1
      • Be cautious as you remove the DVD shield, the edges are sharp and could cut you
      • Lift the DVD drive shield upward and remove it from the Wii.
      Ask FixBot
    5. Nintendo Wii Heat Sink Replacement: step 19, image 1 of 1
      • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
      Ask FixBot
    6. Nintendo Wii Heat Sink Replacement: step 20, image 1 of 1
      • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
      • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
      Ask FixBot
    7. Nintendo Wii Heat Sink Replacement: step 21, image 1 of 1
      • Pull the DVD drive power cable away from its socket on the DVD drive.
      Ask FixBot
    8. Nintendo Wii Heat Sink Replacement: step 22, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 22, image 2 of 2
      • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the DVD drive ribbon cable out of its socket.
      • Remove the DVD drive from the Wii.
      Ask FixBot
    1. Nintendo Wii Heat Sink Replacement, Motherboard Cover: step 23, image 1 of 1
      Buy
      • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
      • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
      Ask FixBot
    2. Nintendo Wii Heat Sink Replacement: step 24, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 24, image 2 of 2
      • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
      • Remove the fan from the Wii.
      Ask FixBot
    3. Nintendo Wii Heat Sink Replacement: step 25, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 25, image 2 of 2
      • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
      • Lift the Wi-Fi antenna out of the fan shroud.
      Ask FixBot
    4. Nintendo Wii Heat Sink Replacement: step 26, image 1 of 1
      • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
      Ask FixBot
    5. Nintendo Wii Heat Sink Replacement: step 27, image 1 of 1
      • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
      Ask FixBot
    6. Nintendo Wii Heat Sink Replacement: step 28, image 1 of 1
      • Carefully de-route both antennas from the frame of the Wii and lay them aside.
      Ask FixBot
    7. Nintendo Wii Heat Sink Replacement: step 29, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 29, image 2 of 2
      • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
      • Lift the fan shroud off the heat sink and remove it from the Wii.
      Ask FixBot
    8. Nintendo Wii Heat Sink Replacement: step 30, image 1 of 3 Nintendo Wii Heat Sink Replacement: step 30, image 2 of 3 Nintendo Wii Heat Sink Replacement: step 30, image 3 of 3
      • Remove the following six screws securing the EMI fingers to the bottom panel:
      • Four 7 mm Phillips screws
      • Two 11.3 mm Phillips screws
      • Remove both sets of EMI fingers from the Wii.
      Ask FixBot
    9. Nintendo Wii Heat Sink Replacement: step 31, image 1 of 2 Nintendo Wii Heat Sink Replacement: step 31, image 2 of 2
      • Remove the following three screws:
      • One 7 mm Phillips screw
      • Two 10 mm Phillips screws
      • Lift the bracket out of the Wii.
      Ask FixBot
    10. Nintendo Wii Heat Sink Replacement: step 32, image 1 of 3 Nintendo Wii Heat Sink Replacement: step 32, image 2 of 3 Nintendo Wii Heat Sink Replacement: step 32, image 3 of 3
      • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
      • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
      • Remove the bracket from the Wii.
      • Be sure not to lose the small square nut loosely held by the black plastic bracket.
      Ask FixBot
    11. Nintendo Wii Heat Sink Replacement: step 33, image 1 of 1
      • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
      Ask FixBot
    12. Nintendo Wii Heat Sink Replacement: step 34, image 1 of 1
      • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
      • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
      Ask FixBot
    1. Nintendo Wii Heat Sink Replacement, Heat Sink: step 35, image 1 of 1
      • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
      Ask FixBot
    2. Nintendo Wii Heat Sink Replacement: step 36, image 1 of 1
      • Lift the heat sink off the motherboard.
      • When working near the exposed processors, be sure not to disturb the thermal pads if you don't plan to replace them. They are fragile and can tear easily. If you do plan to replace the thermal pads, thermal paste can be used.
      Ask FixBot
24 other people completed this guide.
12 Guide Comments
This guide also works great as a thermal paste replacement guide for the Wii, just remove the old thermal pads and clean off the heatsink, CPU, GPU, and WiFi board, and apply Thermal Grease to the CPU, GPU, And WiFi board.
Lucas Hoekstra (Lucas9810) - Reply Share
Use non-conductive thermal pads, 20x20x1.5 and 15x15x1.5 are what you need.
david1024 - Reply Share
Worked great! Was able to reapply thermal paste on my wii. It’s working great so far!
chris morales - Reply Share
Can we use Thermal Paste instead of Thermal Pads?
Manuel E. Carballo Jr. - Reply Share
Yes, thermal paste can be used. I strongly recommend Thermal Grizzly Kryonaut, as it’s the second-best-performing non-metallic thermal paste on the market (the only better performer is Kryonaut Extreme).
f14trex - Reply Share
Past 24 Hours: 14
Past 7 Days: 92
Past 30 Days: 373
All Time: 36,965
