Up to 20% off select tools
Nintendo Wii Fan Replacement
Views: 52K
View statistics:
Past 24 Hours:
10
Past 7 Days:
87
Past 30 Days:
304
All Time:
52,315
Comments: 99
89 comments on steps, 10 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 30
30 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out fan.
    1. Nintendo Wii Fan Replacement, Faceplate: step 1, image 1 of 2 Nintendo Wii Fan Replacement, Faceplate: step 1, image 2 of 2
      • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
      Ask FixBot
    2. Nintendo Wii Fan Replacement: step 2, image 1 of 1
      • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
      Ask FixBot
    3. Nintendo Wii Fan Replacement: step 3, image 1 of 1
      • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
      Ask FixBot
    4. Nintendo Wii Fan Replacement: step 4, image 1 of 1
      • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
      Ask FixBot
    5. Nintendo Wii Fan Replacement: step 5, image 1 of 1
      • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
      Ask FixBot
    6. Nintendo Wii Fan Replacement: step 6, image 1 of 2 Nintendo Wii Fan Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully pull the faceplate away from the front of the Wii.
      • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
      • Remove the faceplate.
      Ask FixBot
    1. Nintendo Wii Fan Replacement, Outer Case: step 7, image 1 of 3 Nintendo Wii Fan Replacement, Outer Case: step 7, image 2 of 3 Nintendo Wii Fan Replacement, Outer Case: step 7, image 3 of 3
      • Open the controller port cover until it is perpendicular to the black controller port bezel.
      • Pull the controller port cover straight up to release it from the outer case.
      • Repeat this procedure for the memory card port cover.
      Ask FixBot
    2. Nintendo Wii Fan Replacement: step 8, image 1 of 2 Nintendo Wii Fan Replacement: step 8, image 2 of 2
      • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
      • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
      Ask FixBot
    3. Nintendo Wii Fan Replacement: step 9, image 1 of 1
      • Remove the two 5 mm Phillips screws above the controller ports.
      Ask FixBot
    4. Nintendo Wii Fan Replacement: step 10, image 1 of 1
      • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
      Ask FixBot
    5. Nintendo Wii Fan Replacement: step 11, image 1 of 1
      • Remove the following screws:
      • Two 5 mm Phillips screws
      • One 8.2 mm Tri-Point screw
      Ask FixBot
    6. Nintendo Wii Fan Replacement: step 12, image 1 of 1
      • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
      Ask FixBot
    7. Nintendo Wii Fan Replacement: step 13, image 1 of 1
      iFixit Precision 4 mm Screwdriver Bit
      $2.99
      Buy
      • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
      • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
      Ask FixBot
    8. Nintendo Wii Fan Replacement: step 14, image 1 of 1
      • Lift the outer case straight up off the body of the Wii.
      Ask FixBot
    1. Nintendo Wii Fan Replacement, Fan: step 15, image 1 of 1
      Buy
      • Grab the fan connector with a pair of tweezers and lift it straight up and out of its socket on the motherboard.
      • Be sure your tweezers are clamped down on the fan connector, not the socket attached to the motherboard.
      Ask FixBot
    2. Nintendo Wii Fan Replacement: step 16, image 1 of 1
      • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
      Ask FixBot
    3. Nintendo Wii Fan Replacement: step 17, image 1 of 1
      • Remove the fan from the Wii.
      Ask FixBot
36 other people completed this guide.
Author
with
10 Guide Comments
Awesome guide, just replaced faulty fan unit in my 9 year old wii. Should hopefully keep it going for another 9 years :)
Finlay Macrae - Reply Share
Super easy and great instructions! I feel a little guilty that my Wii sat in the garage for 4 years! Now it'll be a great birthday present for my 2 boys.
e_gayheart - Reply Share
Does anyone have a diagram for the Wii’s airflow? I’m looking to install a booster fan at the bottom to help blow air in but I want to make sure it is effective.
Jessica Parnelli Fawkes - Reply Share
nice¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Reply Share
Thanks! Wii Quarantine’n in 2021!
Daniel Thomas - Reply Share
Past 24 Hours: 10
Past 7 Days: 87
Past 30 Days: 304
All Time: 52,315
