Up to 20% off select tools
Nintendo WaveBird Wireless Controller Joystick Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
141
All Time:
12,199
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will show you the steps on installing the joystick. This will be helpful if the joystick isn't working properly.
    1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: step 1, image 2 of 2
      • Pull down on the battery cover release lever and pull back to remove the cover.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Joystick Replacement: step 2, image 1 of 1
      • Remove both batteries from the device.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: step 3, image 2 of 2
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Joystick Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement: step 4, image 2 of 2
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 1 of 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 2 of 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: step 6, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: step 6, image 2 of 2
      • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
      • Pull off the grey joystick cover.
      • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
      Ask FixBot
9 other people completed this guide.
Author
with
Garrett Leung
1,012 Reputation
8 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
180 Guides authored
1 Guide Comment
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 141
All Time: 12,199
