Up to 20% off select tools
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
110
All Time:
3,122
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Nintendo WaveBird wireless controller channel wheel guide will allow the user to change the channel wheel if it won’t turn. Prior to replacing the part, ensure that dirt clogging the wheel is not the cause of malfunctioning.  If the wheel and controller is clean and the wheel still fails to turn, a faulty channel wheel is likely the issue.
While replacing the channel wheel, take care with removing the motherboard to avoid damaging the motherboard.  In addition, check the condition of the AA batteries to ensure that they are not swollen or leaking.
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: step 1, image 2 of 2
      • Pull down on the battery cover release lever and pull back to remove the cover.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 2, image 1 of 1
      • Remove both batteries from the device.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: step 3, image 2 of 2
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 4, image 2 of 2
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: step 5, image 1 of 3 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: step 5, image 2 of 3 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: step 6, image 1 of 1
      Buy
      • Using tweezers remove the three grey button pads from the motherboard.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 7, image 1 of 1
      • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
      • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: step 8, image 1 of 1
      • Turn the motherboard over so the channel wheel is facing up.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 9, image 1 of 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: step 9, image 2 of 2
      • Pinch the wheel and pull it away from the motherboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Travis Taylor
563 Reputation
5 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 110
All Time: 3,122
