Up to 20% off select tools
Nintendo WaveBird Wireless Controller Buttons Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
113
All Time:
4,708
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to replace defective buttons. You may need to clean under the buttons if you have sticky buttons.
    1. Nintendo WaveBird Wireless Controller Buttons Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Buttons Replacement, Batteries: step 1, image 2 of 2
      • Pull down on the battery cover release lever and pull back to remove the cover.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Buttons Replacement: step 2, image 1 of 1
      • Remove both batteries from the device.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Buttons Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Buttons Replacement, Front Panel: step 3, image 2 of 2
      • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
      • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
      Ask FixBot
    2. Nintendo WaveBird Wireless Controller Buttons Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Buttons Replacement: step 4, image 2 of 2
      • Carefully turn over the controller and place it on a flat surface.
      • Slowly separate the top panel from the bottom panel.
      • The buttons are loose and may fall off the motherboard.
      • Once separated, set aside the top panel.
      • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
      Ask FixBot
    1. Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: step 5, image 1 of 3 Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: step 5, image 2 of 3 Nintendo WaveBird Wireless Controller Buttons Replacement, Buttons: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the buttons.
      • It may be easier to remove the A button off of the pad by lifting it with your fingers.
      • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
      Ask FixBot
6 other people completed this guide.
Author
with
Douglas
62 Reputation
1 Guide authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 113
All Time: 4,708
