Up to 20% off select tools
Nintendo Switch Rear Panel Replacement
Views: 135K
View statistics:
Past 24 Hours:
34
Past 7 Days:
262
Past 30 Days:
1,085
All Time:
134,599
Comments: 75
64 comments on steps, 11 guide comments.
Go to guide comments
Completed: 94
94 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a cracked or damaged rear panel on the Nintendo Switch.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
    1. Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Ask FixBot
    2. Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Ask FixBot
    3. Nintendo Switch Rear Panel Replacement, Remove the back-side screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Ask FixBot
    4. Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Ask FixBot
    5. Nintendo Switch Rear Panel Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Rear Panel Replacement, Remove the center side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Ask FixBot
    6. Nintendo Switch Rear Panel Replacement: step 6, image 1 of 2 Nintendo Switch Rear Panel Replacement: step 6, image 2 of 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Ask FixBot
    7. Nintendo Switch Rear Panel Replacement, Remove the kickstand well screw: step 7, image 1 of 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Ask FixBot
    8. Nintendo Switch Rear Panel Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Rear Panel Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Rear Panel Replacement, Remove the rear panel: step 8, image 3 of 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
94 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
11 Guide Comments
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - Reply Share
You can transfer the grill to the new back plat
Phillip Norton - Reply Share
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - Reply Share
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - Reply Share
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - Reply Share
Past 24 Hours: 34
Past 7 Days: 262
Past 30 Days: 1,085
All Time: 134,599
