Nintendo Switch OLED Model Dock Baseplate Replacement
    1. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: step 1, image 1 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: step 1, image 2 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: step 1, image 3 of 3
      • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
      • Remove the rear cover.
      Ask FixBot
    2. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: step 2, image 1 of 2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: step 2, image 2 of 2
      • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
      Ask FixBot
    3. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: step 3, image 1 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: step 3, image 2 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: step 3, image 3 of 3
      • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
      • Pry up with the opening tool to separate the screw cover from the frame.
      • Remove the screw cover.
      Ask FixBot
    4. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: step 4, image 1 of 2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: step 4, image 2 of 2
      • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
      • Four 3.9 mm screws
      • Three 7.5 mm screws
      • One 3.9 mm screw
      Ask FixBot
    5. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: step 5, image 1 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: step 5, image 2 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: step 5, image 3 of 3
      • Use your fingers to remove the midframe from the frame.
      Ask FixBot
    6. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: step 6, image 1 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: step 6, image 2 of 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: step 6, image 3 of 3
      • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
      • Remove the baseplate.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Alex Diaz-Kokaisl
250,475 Reputation
1,201 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,996 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 118
All Time: 3,883
