Up to 20% off select tools
Nintendo Switch Motherboard Replacement
Views: 254K
View statistics:
Past 24 Hours:
97
Past 7 Days:
475
Past 30 Days:
2,085
All Time:
253,958
Comments: 211
191 comments on steps, 20 guide comments.
Go to guide comments
Completed: 120
120 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a faulty motherboard in the Nintendo Switch game console.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Normal thermal paste isn't designed to bridge large gaps, so you'll need thermal putty or viscous thermal paste. You will, however, need regular replacement thermal paste for the CPU.
Note: There are two different models for the Nintendo Switch (model HAC-001, released in 2017, and model HAC-001(-01), released in 2019). Make sure your replacement motherboard is compatible with your specific Switch console.
    1. Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Ask FixBot
    2. Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement, Remove the back-side screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Ask FixBot
    4. Nintendo Switch Motherboard Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Motherboard Replacement, Remove the top and bottom screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Ask FixBot
    5. Nintendo Switch Motherboard Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Motherboard Replacement, Remove the center side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Ask FixBot
    6. Nintendo Switch Motherboard Replacement: step 6, image 1 of 2 Nintendo Switch Motherboard Replacement: step 6, image 2 of 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Ask FixBot
    7. Nintendo Switch Motherboard Replacement, Remove the kickstand well screw: step 7, image 1 of 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Ask FixBot
    8. Nintendo Switch Motherboard Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Motherboard Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Motherboard Replacement, Remove the rear panel: step 8, image 3 of 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Remove the microSD card reader: step 9, image 1 of 1
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      Ask FixBot
    2. Nintendo Switch Motherboard Replacement: step 10, image 1 of 3 Nintendo Switch Motherboard Replacement: step 10, image 2 of 3 Nintendo Switch Motherboard Replacement: step 10, image 3 of 3
      • Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement, Reassembly information: step 11, image 1 of 3 Nintendo Switch Motherboard Replacement, Reassembly information: step 11, image 2 of 3 Nintendo Switch Motherboard Replacement, Reassembly information: step 11, image 3 of 3
      • During reassembly:
      • Peel the foam block off the MicroSD card reader.
      • Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Set the foam block onto the connector and press it into place.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Remove the shield plate: step 12, image 1 of 1
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
      Ask FixBot
    2. Nintendo Switch Motherboard Replacement: step 13, image 1 of 2 Nintendo Switch Motherboard Replacement: step 13, image 2 of 2
      Buy
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement: step 14, image 1 of 3 Nintendo Switch Motherboard Replacement: step 14, image 2 of 3 Nintendo Switch Motherboard Replacement: step 14, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Disconnect the battery: step 15, image 1 of 2 Nintendo Switch Motherboard Replacement, Disconnect the battery: step 15, image 2 of 2
      • Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Remove the heat sink: step 16, image 1 of 1
      • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    2. Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      • The foam is really delicate and tears easily. Use the following technique to peel the foam:
      • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
      • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
      • Press the top of the foam with your finger to hold it in place.
      • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement: step 18, image 1 of 3 Nintendo Switch Motherboard Replacement: step 18, image 2 of 3 Nintendo Switch Motherboard Replacement: step 18, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
      • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Remove the headphone jack and game card reader: step 19, image 1 of 2 Nintendo Switch Motherboard Replacement, Remove the headphone jack and game card reader: step 19, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Motherboard Replacement: step 20, image 1 of 2 Nintendo Switch Motherboard Replacement: step 20, image 2 of 2
      Buy
      • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
      • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
      • With the cable parallel to the board, gently slide it into its connector.
      • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
      • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement: step 21, image 1 of 2 Nintendo Switch Motherboard Replacement: step 21, image 2 of 2
      • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
      Ask FixBot
    4. Nintendo Switch Motherboard Replacement: step 22, image 1 of 1
      • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
      Ask FixBot
    5. Nintendo Switch Motherboard Replacement: step 23, image 1 of 2 Nintendo Switch Motherboard Replacement: step 23, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
      Ask FixBot
    6. Nintendo Switch Motherboard Replacement: step 24, image 1 of 2 Nintendo Switch Motherboard Replacement: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
      Ask FixBot
    1. Nintendo Switch Motherboard Replacement, Remove the motherboard: step 25, image 1 of 2 Nintendo Switch Motherboard Replacement, Remove the motherboard: step 25, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
      Ask FixBot
    2. Nintendo Switch Motherboard Replacement: step 26, image 1 of 2 Nintendo Switch Motherboard Replacement: step 26, image 2 of 2
      Buy
      • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Motherboard Replacement: step 27, image 1 of 2 Nintendo Switch Motherboard Replacement: step 27, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
      Ask FixBot
    4. Nintendo Switch Motherboard Replacement: step 28, image 1 of 2 Nintendo Switch Motherboard Replacement: step 28, image 2 of 2
      • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
      Ask FixBot
    5. Nintendo Switch Motherboard Replacement: step 29, image 1 of 2 Nintendo Switch Motherboard Replacement: step 29, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power and volume button ribbon cable ZIF connector.
      Ask FixBot
    6. Nintendo Switch Motherboard Replacement: step 30, image 1 of 2 Nintendo Switch Motherboard Replacement: step 30, image 2 of 2
      Ask FixBot
    7. Nintendo Switch Motherboard Replacement: step 31, image 1 of 2 Nintendo Switch Motherboard Replacement: step 31, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
      Ask FixBot
    8. Nintendo Switch Motherboard Replacement: step 32, image 1 of 2 Nintendo Switch Motherboard Replacement: step 32, image 2 of 2
      Ask FixBot
    9. Nintendo Switch Motherboard Replacement: step 33, image 1 of 2 Nintendo Switch Motherboard Replacement: step 33, image 2 of 2
      • Use the point of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail's data cable ZIF connector.
      Ask FixBot
    10. Nintendo Switch Motherboard Replacement: step 34, image 1 of 2 Nintendo Switch Motherboard Replacement: step 34, image 2 of 2
      Ask FixBot
    11. Nintendo Switch Motherboard Replacement: step 35, image 1 of 2 Nintendo Switch Motherboard Replacement: step 35, image 2 of 2
      • Use the point of a spudger to pry up the black antenna cable straight up out of its socket on the motherboard.
      Ask FixBot
    12. Nintendo Switch Motherboard Replacement: step 36, image 1 of 2 Nintendo Switch Motherboard Replacement: step 36, image 2 of 2
      • Use the point of a spudger to pry up the white antenna cable straight up out of its socket on the motherboard.
      Ask FixBot
    13. Nintendo Switch Motherboard Replacement: step 37, image 1 of 2 Nintendo Switch Motherboard Replacement: step 37, image 2 of 2
      • Use your fingers or a pair of tweezers to pull the right speaker connector straight out of its socket on the motherboard.
      • Do not pull on the connector by the speaker wires. They're very thin and can easily snap off the connector.
      Ask FixBot
    14. Nintendo Switch Motherboard Replacement: step 38, image 1 of 2 Nintendo Switch Motherboard Replacement: step 38, image 2 of 2
      • Use your fingers or a pair of tweezers to pull the left speaker connector straight out of its socket on the motherboard.
      Ask FixBot
    15. Nintendo Switch Motherboard Replacement: step 39, image 1 of 2 Nintendo Switch Motherboard Replacement: step 39, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail data cable ZIF connector.
      Ask FixBot
    16. Nintendo Switch Motherboard Replacement: step 40, image 1 of 2 Nintendo Switch Motherboard Replacement: step 40, image 2 of 2
      • Use a pair of tweezers to slide the Joy Con rail data cable straight out of its connector on the motherboard.
      Ask FixBot
    17. Nintendo Switch Motherboard Replacement: step 41, image 1 of 1
      • Use a JIS 00 driver to remove the following screws:
      • Four 2.5 mm screws
      • Two 3.1 mm screws
      Ask FixBot
    18. Nintendo Switch Motherboard Replacement: step 42, image 1 of 3 Nintendo Switch Motherboard Replacement: step 42, image 2 of 3 Nintendo Switch Motherboard Replacement: step 42, image 3 of 3
      • Insert a spudger into a gap between the motherboard and the frame.
      • Carefully lift up the motherboard and remove it from the frame.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
120 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
20 Guide Comments
Great guide! Thank you. Just one problem: Where the !&&* can I buy a replacement?
Rob - Reply Share
You can buy one on the ifixit parts store or you can find a used one on eBay.
HeyJacksonY - Reply Share
What’s the name of the grey compound you insert on the cooper section on the motherboard? I’ve been wondering what that stuff is.
Steven Peck - Reply Share
That is thermal compound or commonly known as thermal paste. It improves performance of parts by bridging the gaps between the CPU and heat pipes.
If you get a used motherboard is there any issues with login credentials? I assume the system memory and everything is located on this motherboard?
nrb_o_21 - Reply Share
Past 24 Hours: 97
Past 7 Days: 475
Past 30 Days: 2,085
All Time: 253,958
