Up to 20% off select tools
Nintendo Switch Micro SD Card Reader Replacement
Views: 289K
View statistics:
Past 24 Hours:
78
Past 7 Days:
495
Past 30 Days:
2,473
All Time:
288,602
Comments: 169
103 comments on steps, 66 guide comments.
Go to guide comments
Completed: 184
184 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a damaged or faulty microSD card reader on your Nintendo Switch game console.
The Nintendo Switch uses JIS screws, which are slightly different than Phillips. We don’t recommend using Phillips drivers for JIS screws; however, iFixit Phillips bits are specifically designed to be compatible with JIS screws. If you use a non-iFixit Phillips driver, you risk stripping the screws.
WARNING: The battery cannot be disconnected during this repair, so make sure to only use ESD-safe tools and be extra careful when using any metal tools. Not doing so could short a connection and damage the device.
Note: This guide, and the part we sell, are compatible with the original Nintendo Switch model released in 2017, as well as the newer refreshed model released in 2019 (model numbers HAC-001 and HAC-001(-01), respectively).
    1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Ask FixBot
    2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Ask FixBot
    3. Nintendo Switch Micro SD Card Reader Replacement, Remove the back-side screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Ask FixBot
    4. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Ask FixBot
    5. Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Ask FixBot
    6. Nintendo Switch Micro SD Card Reader Replacement: step 6, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 6, image 2 of 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Ask FixBot
    7. Nintendo Switch Micro SD Card Reader Replacement, Remove the kickstand well screw: step 7, image 1 of 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Ask FixBot
    8. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: step 8, image 3 of 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Ask FixBot
    1. Nintendo Switch Micro SD Card Reader Replacement, Remove the microSD card reader: step 9, image 1 of 1
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      Ask FixBot
    2. Nintendo Switch Micro SD Card Reader Replacement: step 10, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement: step 10, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement: step 10, image 3 of 3
      • Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      Ask FixBot
    3. Nintendo Switch Micro SD Card Reader Replacement, Reassembly information: step 11, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Reassembly information: step 11, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Reassembly information: step 11, image 3 of 3
      • During reassembly:
      • Peel the foam block off the MicroSD card reader.
      • Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Set the foam block onto the connector and press it into place.
      Ask FixBot
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
184 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
66 Guide Comments
My SD reader never worked.
Used this guide to find that it was never seated correctly. Reseated and now works perfectly. THANK YOU!
Finx O'Mally - Reply Share
My console won’t boot if I have an SD card inserted after reseating it. What should I do?
Ewan MacInnis - Reply Share
Dont. Just dont
Martin Vincent (i forgo) - Reply Share
Easy guide, fixed my problem. Changed the SD card reader cause I was abusing of it by putting SD in and out constantly.
Nicola Bonardi - Reply Share
Great guide! My 11-year-old son was able to fix his Switch himself with no difficulty.
Matt - Reply Share
Past 24 Hours: 78
Past 7 Days: 495
Past 30 Days: 2,473
All Time: 288,602
