Up to 20% off select tools
Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement
Views: 20K
View statistics:
Past 24 Hours:
15
Past 7 Days:
79
Past 30 Days:
407
All Time:
19,578
Comments: 10
7 comments on steps, 3 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
With extended use over time, Switch models may malfunction. This guide will cover how to replace a malfunctioning SD card reader. The Switch system is widely recognized for its limited internal storage capacity, hence it may prove challenging for users to download and install additional game titles without a properly functioning SD card.
To fix an SD card reader you need to replace the FPC connector socket which connects the SD card reader to the motherboard allowing it to properly function.
  • For this project, experience with applying flux is strongly recommended.
  • Additionally, you should have prior knowledge of how to use a heat gun.
    1. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Prepare the console: step 1, image 1 of 2 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Prepare the console: step 1, image 2 of 2
      • Locate the power button on the top of the Nintendo Switch; it is the indented circular button to the left of the volume buttons and is circled in red in the first image.
      • Press and hold the Power button for three seconds, a power options menu will pop up. Select “Turn Off” in the options menu to power off the Nintendo Switch.
      • Press and hold the black buttons on the back of the joy cons, and slide them upward to remove them. These buttons are circled in yellow in the second image.
      Ask FixBot
    2. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 2, image 1 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 2, image 2 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 2, image 3 of 3
      • Locate the five Phillips head #00 screws on each side of the device and remove them.
      • Locate the two Phillips head #00 screws from the bottom of the device and remove them.
      Ask FixBot
    3. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Remove the back cover: step 3, image 1 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Remove the back cover: step 3, image 2 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Remove the back cover: step 3, image 3 of 3
      • Locate the four tri-wing Y0 screws on the back of the device and remove them.
      • Lift the SD card cover and remove the Phillips head #00 screw from the back of the device.
      • Locate the Phillips head #00 screw on the top of the back cover next to the fan vent and remove it.
      • Carefully remove the back cover from the device.
      Ask FixBot
    4. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Remove the SD card reader: step 4, image 1 of 2 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Remove the SD card reader: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the Phillips head #00 screw securing the microSD card reader to the device and remove it.
      • Slowly remove the SD card reader using tweezers.
      • Improper removal or insertion of the SD card reader can damage either the card reader or the connector socket.
      • During reassembly, make sure to firmly connect the press connector to the motherboard.
      • To make it easier to remove and reinstall the card reader, you may find it helpful to remove the foam pad beforehand.
      Ask FixBot
    5. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Take out the metal plate: step 5, image 1 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Take out the metal plate: step 5, image 2 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Take out the metal plate: step 5, image 3 of 3
      • Locate the six Phillips head #00 screws from the metal plate inside of the device and remove them
      Ask FixBot
    6. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 6, image 1 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 6, image 2 of 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 6, image 3 of 3
      • Using the heat gun apply 400°C heat to the connector socket for 30 seconds to loosen the flux.
      • Remove the metal cover plate
      • Carefully remove the FPC connector socket using the tweezers.
      • Be careful with the heat gun in order to prevent harm to other parts or yourself
      • It is encouraged to wear heat-resistant gloves and to cover other components with aluminum foil or another metal casing.
      Ask FixBot
    7. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Reapply flux: step 7, image 1 of 2 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement, Reapply flux: step 7, image 2 of 2
      • Apply a new coat of flux.
      • Smoothen the surface area using a cotton swab.
      • Insert the new connector socket into the flux.
      Ask FixBot
    8. Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 8, image 1 of 2 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: step 8, image 2 of 2
      • Use the heat gun to apply 400°C to the new flux to loosen it.
      • Use the cotton swab to ensure that the FPC connector socket is completely secured in the flux.
      Ask FixBot
6 other people completed this guide.
Author
with
John Frantz
240 Reputation
1 Guide authored
3 Guide Comments
Question about step 6. "Using the heat gun apply 400°C heat to the connector socket for 30 seconds to loosen the flux." Are you supposed to apply flux before using the heat gun? Or is the flux already on the connector/board from the factory?
David Claycomb (demTICKSdoe) - Reply Share
Please do not follow this guide. You can see the OP melted one of the flex connectors in the process of removing the FPC. The proper procedure is to remove the board and mask the components off with kapton tape.
Sam2G - Reply Share
True. How to do this professionally: https://www.youtube.com/watch?v=HnSi7Pen...
"In this video, I'm going to show you Fix Nintendo Switch Sd Card Reader Connector (Connector Replaced)"
Pixel - Reply Share
Past 24 Hours: 15
Past 7 Days: 79
Past 30 Days: 407
All Time: 19,578
