Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to remove or replace the shield plate inside the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: Removing the shield plate will require cleaning off thermal paste and reapplying it to the heatsink.
Tool used on this step:Magnetic Project Mat$16.96
Use a Y00 screwdriver to remove the four 6.3Â mm-long screws securing the back panel.
Use a JIS 00 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
Two 3.6 mm-long screws on the top of the device
Two 3.6 mm-long screws on the bottom of the device
Insert an opening tool into the left speaker grille on the bottom of the device.
Twist the opening tool to release the clips securing the back panel.
Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
Insert an opening tool into the right speaker grille on the bottom of the device.
Twist the opening tool to release the clips.
Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
Lift the bottom edge of the back panel, opening it like a book.
Remove the back panel.
Use a JIS 00 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
Three 3.1 mm screws
One 4.5 mm screw
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
9 other people completed this guide.
