Nintendo Switch Lite Motherboard Replacement
    1. Nintendo Switch Lite Motherboard Replacement, Remove the back panel screws: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Before beginning this repair, make sure that the device is completely turned off.
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: step 2, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: step 2, image 2 of 2
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
      • Two 3.6 mm-long screws on the top of the device
      • Two 3.6 mm-long screws on the bottom of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: step 3, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: step 3, image 2 of 2
      • Insert an opening tool into the left speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips securing the back panel.
      • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
      Ask FixBot
    4. Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: step 4, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: step 4, image 2 of 2
      • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
      Ask FixBot
    5. Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: step 5, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: step 5, image 2 of 2
      • Insert an opening tool into the right speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips.
      Ask FixBot
    6. Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: step 6, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: step 6, image 2 of 2
      • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
      Ask FixBot
    7. Nintendo Switch Lite Motherboard Replacement: step 7, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 7, image 2 of 2
      • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
      Ask FixBot
    8. Nintendo Switch Lite Motherboard Replacement, Remove the back panel: step 8, image 1 of 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: step 8, image 2 of 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: step 8, image 3 of 3
      • Lift the bottom edge of the back panel, opening it like a book.
      • Remove the back panel.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Remove the shield plate: step 9, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
      • Three 3.1 mm screws
      • One 4.5 mm screw
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 10, image 1 of 3 Nintendo Switch Lite Motherboard Replacement: step 10, image 2 of 3 Nintendo Switch Lite Motherboard Replacement: step 10, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Use a spudger or your fingers to lift the shield plate up and out of the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal putty.
      • Remove the shield plate.
      • Clean off the old thermal putty from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal putty to the heat sink before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Disconnect the interconnect cable: step 11, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the interconnect cable: step 11, image 2 of 2
      • Be gentle when lifting this flap—it's easy to accidentally break off.
      • Use your fingernail or an opening tool to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 12, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 12, image 2 of 2
      • Don't use metal tweezers! They can short-circuit the ribbon cable/connector and damage your device.
      • Use a spudger or a pair of non-conductive (nylon or ceramic) tweezers to slide the interconnect cable out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: step 13, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: step 13, image 2 of 2
      • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
      • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Remove the heat sink: step 14, image 1 of 1
      • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 15, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement: step 16, image 1 of 3 Nintendo Switch Lite Motherboard Replacement: step 16, image 2 of 3 Nintendo Switch Lite Motherboard Replacement: step 16, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Remove the game card reader and headphone jack: step 17, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Remove the game card reader and headphone jack: step 17, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 18, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement: step 19, image 1 of 3 Nintendo Switch Lite Motherboard Replacement: step 19, image 2 of 3 Nintendo Switch Lite Motherboard Replacement: step 19, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
      • Remove the game card reader and headphone jack.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Remove the right trigger button assembly: step 20, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 21, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 21, image 2 of 2
      • Remove the right trigger button assembly.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement: step 22, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 22, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
      Ask FixBot
    4. Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: step 23, image 1 of 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: step 23, image 2 of 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: step 23, image 3 of 3
      • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
      • Repeat the same process for the white antenna cable.
      Ask FixBot
    5. Nintendo Switch Lite Motherboard Replacement, Disconnect the fan cable: step 24, image 1 of 1
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
      Ask FixBot
    6. Nintendo Switch Lite Motherboard Replacement: step 25, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 25, image 2 of 2
      • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
      Ask FixBot
    7. Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: step 26, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: step 26, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
      Ask FixBot
    8. Nintendo Switch Lite Motherboard Replacement: step 27, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 27, image 2 of 2
      • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
      Ask FixBot
    9. Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: step 28, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: step 28, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    10. Nintendo Switch Lite Motherboard Replacement: step 29, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 29, image 2 of 2
      • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
      Ask FixBot
    11. Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: step 30, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: step 30, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
      Ask FixBot
    12. Nintendo Switch Lite Motherboard Replacement: step 31, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 31, image 2 of 2
      • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
      Ask FixBot
    13. Nintendo Switch Lite Motherboard Replacement, Remove the motherboard assembly: step 32, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following six screws securing the motherboard:
      • Three 4.5 mm screws
      Ask FixBot
    14. Nintendo Switch Lite Motherboard Replacement: step 33, image 1 of 3 Nintendo Switch Lite Motherboard Replacement: step 33, image 2 of 3 Nintendo Switch Lite Motherboard Replacement: step 33, image 3 of 3
      • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
      • Remove the motherboard assembly.
      Ask FixBot
    1. Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: step 34, image 1 of 2 Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: step 34, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
      Ask FixBot
    2. Nintendo Switch Lite Motherboard Replacement: step 35, image 1 of 2 Nintendo Switch Lite Motherboard Replacement: step 35, image 2 of 2
      • Remove the right speaker module from the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Motherboard Replacement: step 36, image 1 of 1
      • Only the motherboard remains.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
29 other people completed this guide.
Craig Lloyd
43,642 Reputation
82 Guides authored
10 Guide Comments
Great guide, helped me fix charge port replacement, did notice between 16-17 the card reader magically disappeared, but help me tear down and repair and rebuild with a little bit of head scratching.
Sean Topp - Reply Share
La guida è molto chiara.. ma dove si può acquistare una scheda madre di ricambio ?
Walter - Reply Share
It stops at motherboard removal, is there a section for replacing the USB charging port on the switch lite?
Christian Knight - Reply Share
No, you can not replace the port without soldering it. If you aren't good at soldering I would highly advise looking into costs at local repair shops.
Nova - Reply Share
Where can i get the motherboard from, i cant replace the charging port, cause it is soldered to the motherboard. So if you could please let me know onto where i can get the mother board from. 😊
JoyBoy - Reply Share
Past 24 Hours: 30
Past 7 Days: 215
Past 30 Days: 1,115
All Time: 81,705
