Up to 20% off select tools
Nintendo Switch Lite LCD Replacement
Views: 225K
View statistics:
Past 24 Hours:
95
Past 7 Days:
554
Past 30 Days:
2,669
All Time:
224,914
Comments: 120
95 comments on steps, 25 guide comments.
Go to guide comments
Completed: 62
62 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a faulty or damaged LCD on the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: This guide is for the LCD only. If you're replacing the screen (the LCD attached to the digitizer) follow this guide. If the display glass is cracked or shattered, but the LCD still works, you’ll need to replace the digitizer instead.
Note: Removing the joysticks and buttons isn’t required, but it makes this repair much easier.
Note: This procedure requires removing the shield plate and heat sink. The thermal paste will need to be cleaned off of both components—as well as the CPU—and reapplied before reinstalling the shield plate and heat sink.
    1. Nintendo Switch Lite LCD Replacement, Remove the back panel screws: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Before beginning this repair, make sure that the device is completely turned off.
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement, Remove the top and bottom back panel screws: step 2, image 1 of 2 Nintendo Switch Lite LCD Replacement, Remove the top and bottom back panel screws: step 2, image 2 of 2
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
      • Two 3.6 mm-long screws on the top of the device
      • Two 3.6 mm-long screws on the bottom of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement, Release the clips securing the back panel: step 3, image 1 of 2 Nintendo Switch Lite LCD Replacement, Release the clips securing the back panel: step 3, image 2 of 2
      • Insert an opening tool into the left speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips securing the back panel.
      • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
      Ask FixBot
    4. Nintendo Switch Lite LCD Replacement, Continue releasing the clips around the device: step 4, image 1 of 2 Nintendo Switch Lite LCD Replacement, Continue releasing the clips around the device: step 4, image 2 of 2
      • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
      Ask FixBot
    5. Nintendo Switch Lite LCD Replacement, Twist to release the clips: step 5, image 1 of 2 Nintendo Switch Lite LCD Replacement, Twist to release the clips: step 5, image 2 of 2
      • Insert an opening tool into the right speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips.
      Ask FixBot
    6. Nintendo Switch Lite LCD Replacement, Slide and pry around the corners: step 6, image 1 of 2 Nintendo Switch Lite LCD Replacement, Slide and pry around the corners: step 6, image 2 of 2
      • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
      Ask FixBot
    7. Nintendo Switch Lite LCD Replacement: step 7, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 7, image 2 of 2
      • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
      Ask FixBot
    8. Nintendo Switch Lite LCD Replacement, Remove the back panel: step 8, image 1 of 3 Nintendo Switch Lite LCD Replacement, Remove the back panel: step 8, image 2 of 3 Nintendo Switch Lite LCD Replacement, Remove the back panel: step 8, image 3 of 3
      • Lift the bottom edge of the back panel, opening it like a book.
      • Remove the back panel.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the shield plate: step 9, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
      • Three 3.1 mm screws
      • One 4.5 mm screw
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 10, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 10, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 10, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Use a spudger or your fingers to lift the shield plate up and out of the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal putty.
      • Remove the shield plate.
      • Clean off the old thermal putty from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal putty to the heat sink before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Disconnect the interconnect cable: step 11, image 1 of 3 Nintendo Switch Lite LCD Replacement, Disconnect the interconnect cable: step 11, image 2 of 3 Nintendo Switch Lite LCD Replacement, Disconnect the interconnect cable: step 11, image 3 of 3
      • Be gentle when lifting this flap—it's easy to accidentally break off.
      • Use your fingernail or an opening tool to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 12, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 12, image 2 of 2
      • Don't use metal tweezers! They can short-circuit the ribbon cable/connector and damage your device.
      • Use a spudger or a pair of non-conductive (nylon or ceramic) tweezers to slide the interconnect cable out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement, Disconnect the battery: step 13, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the battery: step 13, image 2 of 2
      • Use the point of a spudger to pry the battery connector, as close to the connector as possible, straight up and out of its socket on the motherboard.
      • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the heat sink: step 14, image 1 of 1
      • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 15, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement: step 16, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 16, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 16, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the game card reader and headphone jack: step 17, image 1 of 2 Nintendo Switch Lite LCD Replacement, Remove the game card reader and headphone jack: step 17, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 18, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement: step 19, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 19, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 19, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
      • Remove the game card reader and headphone jack.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the right trigger button assembly: step 20, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 21, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 21, image 2 of 2
      • Remove the right trigger button assembly.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement: step 22, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 22, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
      Ask FixBot
    4. Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: step 23, image 1 of 3 Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: step 23, image 2 of 3 Nintendo Switch Lite LCD Replacement, Disconnect the antenna cables: step 23, image 3 of 3
      • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
      • Repeat the same process for the white antenna cable.
      Ask FixBot
    5. Nintendo Switch Lite LCD Replacement, Disconnect the fan cable: step 24, image 1 of 1
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
      Ask FixBot
    6. Nintendo Switch Lite LCD Replacement: step 25, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 25, image 2 of 2
      • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
      Ask FixBot
    7. Nintendo Switch Lite LCD Replacement, Disconnect the screen cable: step 26, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the screen cable: step 26, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
      Ask FixBot
    8. Nintendo Switch Lite LCD Replacement: step 27, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 27, image 2 of 2
      • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
      Ask FixBot
    9. Nintendo Switch Lite LCD Replacement, Disconnect the digitizer cable: step 28, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the digitizer cable: step 28, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    10. Nintendo Switch Lite LCD Replacement: step 29, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 29, image 2 of 2
      • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
      Ask FixBot
    11. Nintendo Switch Lite LCD Replacement, Disconnect the right joystick cable: step 30, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the right joystick cable: step 30, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
      Ask FixBot
    12. Nintendo Switch Lite LCD Replacement: step 31, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 31, image 2 of 2
      • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
      Ask FixBot
    13. Nintendo Switch Lite LCD Replacement, Remove the motherboard assembly: step 32, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following six screws securing the motherboard:
      • Three 4.5 mm screws
      Ask FixBot
    14. Nintendo Switch Lite LCD Replacement: step 33, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 33, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 33, image 3 of 3
      • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
      • Remove the motherboard assembly.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the right joystick: step 34, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 3.5 mm screws securing the joystick.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 35, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 35, image 2 of 2
      • Use your fingers to remove the joystick.
      • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the left speaker module: step 36, image 1 of 2 Nintendo Switch Lite LCD Replacement, Remove the left speaker module: step 36, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
      • Do not pull from the wires, or else you risk ripping the wires off the connector.
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 37, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the 4.5 mm screw securing the left speaker module.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement: step 38, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 38, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 38, image 3 of 3
      • Use your fingers to lift the speaker module up and out of its recess to remove it.
      • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
      Ask FixBot
    4. Nintendo Switch Lite LCD Replacement, Disconnect the motherboard interconnect cable: step 39, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the motherboard interconnect cable: step 39, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    5. Nintendo Switch Lite LCD Replacement: step 40, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 40, image 2 of 2
      • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
      Ask FixBot
    6. Nintendo Switch Lite LCD Replacement, Disconnect the screen and volume button cables: step 41, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the screen and volume button cables: step 41, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
      Ask FixBot
    7. Nintendo Switch Lite LCD Replacement: step 42, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 42, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 42, image 3 of 3
      • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
      • Repeat this procedure for the volume buttons cable.
      Ask FixBot
    8. Nintendo Switch Lite LCD Replacement, Remove the volume buttons: step 43, image 1 of 2 Nintendo Switch Lite LCD Replacement, Remove the volume buttons: step 43, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the volume buttons.
      Ask FixBot
    9. Nintendo Switch Lite LCD Replacement, Disconnect the joystick cable: step 44, image 1 of 2 Nintendo Switch Lite LCD Replacement, Disconnect the joystick cable: step 44, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
      Ask FixBot
    10. Nintendo Switch Lite LCD Replacement: step 45, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 45, image 2 of 2
      • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
      Ask FixBot
    11. Nintendo Switch Lite LCD Replacement, Remove the left trigger button assembly: step 46, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 4.5 mm screws securing the left trigger button assembly.
      Ask FixBot
    12. Nintendo Switch Lite LCD Replacement: step 47, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 47, image 2 of 2
      • Remove the left trigger button assembly.
      Ask FixBot
    13. Nintendo Switch Lite LCD Replacement, Remove the daughterboard: step 48, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following four screws:
      • Two 4.5 mm screws
      • Two 6 mm screws
      Ask FixBot
    14. Nintendo Switch Lite LCD Replacement: step 49, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 49, image 2 of 2
      • Use your fingers to lift the daughterboard up and out of its recess to remove it.
      Ask FixBot
    15. Nintendo Switch Lite LCD Replacement, Remove the left joystick: step 50, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 3.5 mm screws securing the left joystick.
      Ask FixBot
    16. Nintendo Switch Lite LCD Replacement: step 51, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 51, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 51, image 3 of 3
      • Use the flat end of a spudger to lift the joystick up and out of its recess.
      Ask FixBot
    1. Nintendo Switch Lite LCD Replacement, Remove the midframe assembly: step 52, image 1 of 1
      • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
      • Three 2.5 mm screws
      • One 6 mm screw
      Ask FixBot
    2. Nintendo Switch Lite LCD Replacement: step 53, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 53, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 53, image 3 of 3
      • Use a spudger or your fingers to lift the midframe assembly up and out of its recess.
      • Remove the midframe assembly.
      Ask FixBot
    3. Nintendo Switch Lite LCD Replacement, Remove the buttons: step 54, image 1 of 2 Nintendo Switch Lite LCD Replacement, Remove the buttons: step 54, image 2 of 2
      • At this point in the repair, remove all of the buttons if you haven't done so already, to prevent them from falling out and getting lost.
      • Use these two photos for reference.
      Ask FixBot
    4. Nintendo Switch Lite LCD Replacement, Remove the LCD: step 55, image 1 of 1
      • Heat an iOpener and apply it to the back side of the LCD along the top edge for 2 minutes.
      • A hair dryer or heat gun may also be used, but be careful not to overheat the LCD if you plan on reusing it, as it's susceptible to heat damage.
      Ask FixBot
    5. Nintendo Switch Lite LCD Replacement: step 56, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 56, image 2 of 2
      • Insert an opening pick between the frame and the top edge of the LCD to begin separating the two components.
      • Make sure to insert the pick completely under the LCD panel so you don't split and damage it.
      • You'll know you're splitting the panel if the silver backing bubbles and separates from the white lining.
      Ask FixBot
    6. Nintendo Switch Lite LCD Replacement: step 57, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 57, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 57, image 3 of 3
      • Slide the opening pick along the top edge of the LCD to slice the adhesive.
      Ask FixBot
    7. Nintendo Switch Lite LCD Replacement: step 58, image 1 of 1
      • Apply a heated iOpener to the back side of the LCD along the right edge for 2 minutes.
      Ask FixBot
    8. Nintendo Switch Lite LCD Replacement: step 59, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 59, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 59, image 3 of 3
      • Continue sliding the opening pick around the right edge of the LCD, slicing the adhesive.
      • The LCD and digitizer cables are placed in a way to prevent them from easily snagging on the opening pick, but still use caution when sliding the opening pick along the gap.
      Ask FixBot
    9. Nintendo Switch Lite LCD Replacement: step 60, image 1 of 1
      • Apply a heated iOpener to the back side of the LCD along the bottom edge for 2 minutes.
      Ask FixBot
    10. Nintendo Switch Lite LCD Replacement: step 61, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 61, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 61, image 3 of 3
      • Continue sliding the opening pick along the bottom edge of the LCD to slice the adhesive.
      • You'll need to remove and reinsert the opening pick at various points along the LCD's edge to work around the frame.
      Ask FixBot
    11. Nintendo Switch Lite LCD Replacement: step 62, image 1 of 1
      • Apply a heated iOpener to the back side of the LCD along the left edge for 2 minutes.
      Ask FixBot
    12. Nintendo Switch Lite LCD Replacement: step 63, image 1 of 2 Nintendo Switch Lite LCD Replacement: step 63, image 2 of 2
      • Continue sliding the opening pick along the left edge of the LCD to slice the adhesive.
      • Take care not to snag the LCD's daughterboard cable on the opening pick.
      Ask FixBot
    13. Nintendo Switch Lite LCD Replacement: step 64, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 64, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 64, image 3 of 3
      • Use the flat end of a spudger or your fingers to lift the LCD up and out of the frame to remove it.
      • If you're reusing the LCD (or your new LCD does not come with pre‑installed adhesive), follow this guide to install pre-cut adhesive around the perimeter before reassembly.
      Ask FixBot
    14. Nintendo Switch Lite LCD Replacement: step 65, image 1 of 3 Nintendo Switch Lite LCD Replacement: step 65, image 2 of 3 Nintendo Switch Lite LCD Replacement: step 65, image 3 of 3
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're also replacing the digitizer, you can skip this step.
      • Use the flat end of a spudger to scrape off the remaining adhesive around the perimeter of the digitizer.
      • Prior to installing a new LCD, use isopropyl alcohol and a microfiber cloth to clean and remove any residual adhesive from the back side of the digitizer. Wait several minutes for any remaining alcohol to evaporate before installing the LCD.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
62 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
25 Guide Comments
Followed the guide to replaced a cracked screen on a Switch Lite, all good, guide was easy to follow and refitting wasn't too hard either, just a reversal of the disassembly
Luke Randall - Reply Share
Fantastic guide, exactly what I was looking for! Unfortunately I managed to make the tape unusable and I need tape to connect the lcd to the digitizer and the digitizer to the case. I will likely use 2-3mm tape for the lcd to digitizer but I'm unsure what to use to connect the digitizer to the case. Any suggestions?
Sam Red - Reply Share
Thanks for taking the time to type this up. Really appreciate the effort that went in to this guide.
Matthew D. H. - Reply Share
Great guide, I wish it would mention some of the procedures to tape the screen back in. After that, reversing the process was easy.
Stephen Hotchkiss - Reply Share
For gluing the screen and digitizer back in, I would strongly recommend liquid glue, like Zhanlida T-8000 for example. You can apply it very precisely and you can also correct/remove it if needed pretty easily. I used this stuff to repair around 200 phones and tablets in the last couple of years and were never disappointed.
Also I would remove the digitizer AND the screen together, before removing the screen first from the digitizer… This will make the process of removing the screen from the digitizer a lot easier and safer.
I have ordered a crystal replacement case and a used lite with a scratched digitizer.. Have glued in the replacement digitizer so far, the console should arrive tomorrow.
Gluing in the digitizer was a breeze, just applied some glue all around (be careful not to use too much) and then just pressed down the digitizer all around and put a book on the top… Let the glue harden for around 24 hours and you are good to go.
Will leave some feedback how the screen removal went tomorrow. ;)
mathiasludewig - Reply Share
Past 24 Hours: 95
Past 7 Days: 554
Past 30 Days: 2,669
All Time: 224,914
