Up to 20% off select tools
Nintendo Switch Lite Fan Replacement
Views: 27K
View statistics:
Past 24 Hours:
28
Past 7 Days:
92
Past 30 Days:
423
All Time:
27,456
Comments: 52
50 comments on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a faulty or damaged fan in the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: This procedure requires removing the shield plate and heat sink. The thermal paste will need to be cleaned off of both components—as well as the CPU—and reapplied before reinstalling the shield plate and heat sink.
    1. Nintendo Switch Lite Fan Replacement, Remove the back panel screws: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Before beginning this repair, make sure that the device is completely turned off.
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
      Ask FixBot
    2. Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: step 2, image 1 of 2 Nintendo Switch Lite Fan Replacement, Remove the top and bottom back panel screws: step 2, image 2 of 2
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
      • Two 3.6 mm-long screws on the top of the device
      • Two 3.6 mm-long screws on the bottom of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      Ask FixBot
    3. Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: step 3, image 1 of 2 Nintendo Switch Lite Fan Replacement, Release the clips securing the back panel: step 3, image 2 of 2
      • Insert an opening tool into the left speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips securing the back panel.
      • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
      Ask FixBot
    4. Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: step 4, image 1 of 2 Nintendo Switch Lite Fan Replacement, Continue releasing the clips around the device: step 4, image 2 of 2
      • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
      Ask FixBot
    5. Nintendo Switch Lite Fan Replacement, Twist to release the clips: step 5, image 1 of 2 Nintendo Switch Lite Fan Replacement, Twist to release the clips: step 5, image 2 of 2
      • Insert an opening tool into the right speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips.
      Ask FixBot
    6. Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: step 6, image 1 of 2 Nintendo Switch Lite Fan Replacement, Slide and pry around the corners: step 6, image 2 of 2
      • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
      Ask FixBot
    7. Nintendo Switch Lite Fan Replacement: step 7, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 7, image 2 of 2
      • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
      Ask FixBot
    8. Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 1 of 3 Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 2 of 3 Nintendo Switch Lite Fan Replacement, Remove the back panel: step 8, image 3 of 3
      • Lift the bottom edge of the back panel, opening it like a book.
      • Remove the back panel.
      Ask FixBot
    1. Nintendo Switch Lite Fan Replacement, Remove the shield plate: step 9, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
      • Three 3.1 mm screws
      • One 4.5 mm screw
      Ask FixBot
    2. Nintendo Switch Lite Fan Replacement: step 10, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 10, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 10, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Use a spudger or your fingers to lift the shield plate up and out of the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal putty.
      • Remove the shield plate.
      • Clean off the old thermal putty from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal putty to the heat sink before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Fan Replacement, Disconnect the interconnect cable: step 11, image 1 of 3 Nintendo Switch Lite Fan Replacement, Disconnect the interconnect cable: step 11, image 2 of 3 Nintendo Switch Lite Fan Replacement, Disconnect the interconnect cable: step 11, image 3 of 3
      • Be gentle when lifting this flap—it's easy to accidentally break off.
      • Use your fingernail or an opening tool to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Fan Replacement: step 12, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 12, image 2 of 2
      • Don't use metal tweezers! They can short-circuit the ribbon cable/connector and damage your device.
      • Use a spudger or a pair of non-conductive (nylon or ceramic) tweezers to slide the interconnect cable out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Fan Replacement, Disconnect the battery: step 13, image 1 of 2 Nintendo Switch Lite Fan Replacement, Disconnect the battery: step 13, image 2 of 2
      • Use the point of a spudger to pry the battery connector, as close to the connector as possible, straight up and out of its socket on the motherboard.
      • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
      Ask FixBot
    1. Nintendo Switch Lite Fan Replacement, Remove the heat sink: step 14, image 1 of 1
      • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      Ask FixBot
    2. Nintendo Switch Lite Fan Replacement: step 15, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Fan Replacement: step 16, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 16, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 16, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Fan Replacement, Remove the fan: step 17, image 1 of 2 Nintendo Switch Lite Fan Replacement, Remove the fan: step 17, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Fan Replacement: step 18, image 1 of 2 Nintendo Switch Lite Fan Replacement: step 18, image 2 of 2
      Buy
      • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Fan Replacement: step 19, image 1 of 1
      • Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
      Ask FixBot
    4. Nintendo Switch Lite Fan Replacement: step 20, image 1 of 3 Nintendo Switch Lite Fan Replacement: step 20, image 2 of 3 Nintendo Switch Lite Fan Replacement: step 20, image 3 of 3
      • Remove the fan.
      • Take care not to snag the fan cable on the motherboard as you remove the fan.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
10 other people completed this guide.
Author
with
Craig Lloyd
43,853 Reputation
82 Guides authored
2 Guide Comments
I used this guide to put my new fan in and let me just say THANK YOU!!! All I could find was ones for regular Switches on YouTube and not the Lite. The only problem I had was I'm not sure which side of the cable on the fan should be facing up. I looked on your website and the fan listen on here has one side with a gold part at the end where you insert it into the connector. Is that the side that goes up?
Skylar Neville - Reply Share
Many thanks for this guide it helped me so much it was pretty straight forward to do but attaching the fan ribbon/power cord and trying not to strip the tiny screws heads was probably the hardest bits really
FMG_MADLOO87 (MADLOO) - Reply Share
Past 24 Hours: 28
Past 7 Days: 92
Past 30 Days: 423
All Time: 27,456
