Up to 20% off select tools
Nintendo Switch Front Frame Replacement
Views: 40K
View statistics:
Past 24 Hours:
24
Past 7 Days:
138
Past 30 Days:
672
All Time:
40,210
Comments: 208
204 comments on steps, 4 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 hours
Difficulty: Difficult
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front frame surrounding the midframe and containing the display.
The Switch uses JIS screws. A JIS 00 driver works best, but you can also use a JIS 000 driver. If you use a Phillips driver, you'll risk stripping the screws.
Note that due to the way guides are combined into a single sequence, occasionally a step may be repeated or a picture may show parts in place or absent that aren't related to the particular job being done. In those cases, simply follow the written instructions regarding the actual operation being performed and disregard things like whether the battery is in place or not, for example.
    1. Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Front Frame Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Front Frame Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement, Remove the back-side screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Ask FixBot
    4. Nintendo Switch Front Frame Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Front Frame Replacement, Remove the top and bottom screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Ask FixBot
    5. Nintendo Switch Front Frame Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Front Frame Replacement, Remove the center side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Ask FixBot
    6. Nintendo Switch Front Frame Replacement: step 6, image 1 of 2 Nintendo Switch Front Frame Replacement: step 6, image 2 of 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Ask FixBot
    7. Nintendo Switch Front Frame Replacement, Remove the kickstand well screw: step 7, image 1 of 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Ask FixBot
    8. Nintendo Switch Front Frame Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Front Frame Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Front Frame Replacement, Remove the rear panel: step 8, image 3 of 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the microSD card reader: step 9, image 1 of 1
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement: step 10, image 1 of 3 Nintendo Switch Front Frame Replacement: step 10, image 2 of 3 Nintendo Switch Front Frame Replacement: step 10, image 3 of 3
      • Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement, Reassembly information: step 11, image 1 of 3 Nintendo Switch Front Frame Replacement, Reassembly information: step 11, image 2 of 3 Nintendo Switch Front Frame Replacement, Reassembly information: step 11, image 3 of 3
      • During reassembly:
      • Peel the foam block off the MicroSD card reader.
      • Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Set the foam block onto the connector and press it into place.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the shield plate: step 12, image 1 of 1
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement: step 13, image 1 of 2 Nintendo Switch Front Frame Replacement: step 13, image 2 of 2
      Buy
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement: step 14, image 1 of 3 Nintendo Switch Front Frame Replacement: step 14, image 2 of 3 Nintendo Switch Front Frame Replacement: step 14, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Disconnect the battery: step 15, image 1 of 2 Nintendo Switch Front Frame Replacement, Disconnect the battery: step 15, image 2 of 2
      • Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the heat sink: step 16, image 1 of 1
      • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    2. Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      • The foam is really delicate and tears easily. Use the following technique to peel the foam:
      • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
      • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
      • Press the top of the foam with your finger to hold it in place.
      • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement: step 18, image 1 of 3 Nintendo Switch Front Frame Replacement: step 18, image 2 of 3 Nintendo Switch Front Frame Replacement: step 18, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
      • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the headphone jack and game card reader: step 19, image 1 of 2 Nintendo Switch Front Frame Replacement, Remove the headphone jack and game card reader: step 19, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement: step 20, image 1 of 2 Nintendo Switch Front Frame Replacement: step 20, image 2 of 2
      Buy
      • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
      • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
      • With the cable parallel to the board, gently slide it into its connector.
      • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
      • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement: step 21, image 1 of 2 Nintendo Switch Front Frame Replacement: step 21, image 2 of 2
      • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
      Ask FixBot
    4. Nintendo Switch Front Frame Replacement: step 22, image 1 of 1
      • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
      Ask FixBot
    5. Nintendo Switch Front Frame Replacement: step 23, image 1 of 2 Nintendo Switch Front Frame Replacement: step 23, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
      Ask FixBot
    6. Nintendo Switch Front Frame Replacement: step 24, image 1 of 2 Nintendo Switch Front Frame Replacement: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the motherboard: step 25, image 1 of 2 Nintendo Switch Front Frame Replacement, Remove the motherboard: step 25, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement: step 26, image 1 of 2 Nintendo Switch Front Frame Replacement: step 26, image 2 of 2
      Buy
      • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement: step 27, image 1 of 2 Nintendo Switch Front Frame Replacement: step 27, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
      Ask FixBot
    4. Nintendo Switch Front Frame Replacement: step 28, image 1 of 2 Nintendo Switch Front Frame Replacement: step 28, image 2 of 2
      • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
      Ask FixBot
    5. Nintendo Switch Front Frame Replacement: step 29, image 1 of 2 Nintendo Switch Front Frame Replacement: step 29, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power and volume button ribbon cable ZIF connector.
      Ask FixBot
    6. Nintendo Switch Front Frame Replacement: step 30, image 1 of 2 Nintendo Switch Front Frame Replacement: step 30, image 2 of 2
      Ask FixBot
    7. Nintendo Switch Front Frame Replacement: step 31, image 1 of 2 Nintendo Switch Front Frame Replacement: step 31, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
      Ask FixBot
    8. Nintendo Switch Front Frame Replacement: step 32, image 1 of 2 Nintendo Switch Front Frame Replacement: step 32, image 2 of 2
      Ask FixBot
    9. Nintendo Switch Front Frame Replacement: step 33, image 1 of 2 Nintendo Switch Front Frame Replacement: step 33, image 2 of 2
      • Use the point of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail's data cable ZIF connector.
      Ask FixBot
    10. Nintendo Switch Front Frame Replacement: step 34, image 1 of 2 Nintendo Switch Front Frame Replacement: step 34, image 2 of 2
      Ask FixBot
    11. Nintendo Switch Front Frame Replacement: step 35, image 1 of 2 Nintendo Switch Front Frame Replacement: step 35, image 2 of 2
      • Use the point of a spudger to pry up the black antenna cable straight up out of its socket on the motherboard.
      Ask FixBot
    12. Nintendo Switch Front Frame Replacement: step 36, image 1 of 2 Nintendo Switch Front Frame Replacement: step 36, image 2 of 2
      • Use the point of a spudger to pry up the white antenna cable straight up out of its socket on the motherboard.
      Ask FixBot
    13. Nintendo Switch Front Frame Replacement: step 37, image 1 of 2 Nintendo Switch Front Frame Replacement: step 37, image 2 of 2
      • Use your fingers or a pair of tweezers to pull the right speaker connector straight out of its socket on the motherboard.
      • Do not pull on the connector by the speaker wires. They're very thin and can easily snap off the connector.
      Ask FixBot
    14. Nintendo Switch Front Frame Replacement: step 38, image 1 of 2 Nintendo Switch Front Frame Replacement: step 38, image 2 of 2
      • Use your fingers or a pair of tweezers to pull the left speaker connector straight out of its socket on the motherboard.
      Ask FixBot
    15. Nintendo Switch Front Frame Replacement: step 39, image 1 of 2 Nintendo Switch Front Frame Replacement: step 39, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail data cable ZIF connector.
      Ask FixBot
    16. Nintendo Switch Front Frame Replacement: step 40, image 1 of 2 Nintendo Switch Front Frame Replacement: step 40, image 2 of 2
      • Use a pair of tweezers to slide the Joy Con rail data cable straight out of its connector on the motherboard.
      Ask FixBot
    17. Nintendo Switch Front Frame Replacement: step 41, image 1 of 1
      • Use a JIS 00 driver to remove the following screws:
      • Four 2.5 mm screws
      • Two 3.1 mm screws
      Ask FixBot
    18. Nintendo Switch Front Frame Replacement: step 42, image 1 of 3 Nintendo Switch Front Frame Replacement: step 42, image 2 of 3 Nintendo Switch Front Frame Replacement: step 42, image 3 of 3
      • Insert a spudger into a gap between the motherboard and the frame.
      • Carefully lift up the motherboard and remove it from the frame.
      Ask FixBot
    1. Nintendo Switch Front Frame Replacement, Remove the Fan: step 43, image 1 of 1
      • Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
      Ask FixBot
    2. Nintendo Switch Front Frame Replacement: step 44, image 1 of 2 Nintendo Switch Front Frame Replacement: step 44, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
      • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
      Ask FixBot
    3. Nintendo Switch Front Frame Replacement, Remove the Right Joy Con Sensor Rail: step 45, image 1 of 1
      • Use a JIS 00 driver to remove the four 3.7 mm screws securing the right Joy Con rail to the frame of the device.
      • These screws are torqued down and can be difficult to remove. To prevent them from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      Ask FixBot
    4. Nintendo Switch Front Frame Replacement: step 46, image 1 of 2 Nintendo Switch Front Frame Replacement: step 46, image 2 of 2
      • Remove the right Joy Con sensor rail.
      • Take care not to snag the rail's data cable on the device frame as you remove it.
      Ask FixBot
    5. Nintendo Switch Front Frame Replacement, Remove the Left Joy Con Sensor Rail: step 47, image 1 of 2 Nintendo Switch Front Frame Replacement, Remove the Left Joy Con Sensor Rail: step 47, image 2 of 2
      • Use your fingers or a pair of tweezers to lift the battery connector up and out of the way of the Joy Con rail's data cable.
      Ask FixBot
    6. Nintendo Switch Front Frame Replacement: step 48, image 1 of 3 Nintendo Switch Front Frame Replacement: step 48, image 2 of 3 Nintendo Switch Front Frame Replacement: step 48, image 3 of 3
      Ask FixBot
    7. Nintendo Switch Front Frame Replacement: step 49, image 1 of 1
      • Use a JIS 00 driver to remove the four 3.7 mm screws securing the left Joy Con rail to the frame of the device.
      Ask FixBot
    8. Nintendo Switch Front Frame Replacement: step 50, image 1 of 2 Nintendo Switch Front Frame Replacement: step 50, image 2 of 2
      • Remove the left Joy Con sensor rail from the device.
      Ask FixBot
    9. Nintendo Switch Front Frame Replacement, Remove the Power and Volume Button Board: step 51, image 1 of 1
      • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
      Ask FixBot
    10. Nintendo Switch Front Frame Replacement: step 52, image 1 of 2 Nintendo Switch Front Frame Replacement: step 52, image 2 of 2
      • Remove the power/volume board with a pair of blunt nose tweezers.
      Ask FixBot
    11. Nintendo Switch Front Frame Replacement, Remove the Exterior Power and Volume Buttons: step 53, image 1 of 1
      • Pull the rubber conductive pad out with a pair of blunt nose tweezers.
      Ask FixBot
    12. Nintendo Switch Front Frame Replacement: step 54, image 1 of 2 Nintendo Switch Front Frame Replacement: step 54, image 2 of 2
      • Pull the power and volume buttons out with a pair of blunt nose tweezers.
      Ask FixBot
    13. Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: step 55, image 1 of 3 Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: step 55, image 2 of 3 Nintendo Switch Front Frame Replacement, Remove the WiFi Antenna: step 55, image 3 of 3
      • Deroute the black coax cable from the midframe.
      Ask FixBot
    14. Nintendo Switch Front Frame Replacement: step 56, image 1 of 2 Nintendo Switch Front Frame Replacement: step 56, image 2 of 2
      • Continue following the wire, derouting it as you go.
      Ask FixBot
    15. Nintendo Switch Front Frame Replacement: step 57, image 1 of 2 Nintendo Switch Front Frame Replacement: step 57, image 2 of 2
      • Pry the metal barrel surrounding the coax up from the midframe.
      Ask FixBot
    16. Nintendo Switch Front Frame Replacement: step 58, image 1 of 2 Nintendo Switch Front Frame Replacement: step 58, image 2 of 2
      • Grasp the WiFi antenna board with a pair of tweezers and lift straight up to remove it.
      Ask FixBot
    17. Nintendo Switch Front Frame Replacement, Remove the Screen: step 59, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    18. Nintendo Switch Front Frame Replacement: step 60, image 1 of 3 Nintendo Switch Front Frame Replacement: step 60, image 2 of 3 Nintendo Switch Front Frame Replacement: step 60, image 3 of 3
      • Apply a suction cup to the bottom-left corner of the screen.
      • Pull up on the suction up with strong, steady force to create a gap.
      • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
      • Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
      Ask FixBot
    19. Nintendo Switch Front Frame Replacement: step 61, image 1 of 3 Nintendo Switch Front Frame Replacement: step 61, image 2 of 3 Nintendo Switch Front Frame Replacement: step 61, image 3 of 3
      • Slide the opening pick along the bottom edge of the screen to slice the adhesive.
      • Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
      Ask FixBot
    20. Nintendo Switch Front Frame Replacement: step 62, image 1 of 3 Nintendo Switch Front Frame Replacement: step 62, image 2 of 3 Nintendo Switch Front Frame Replacement: step 62, image 3 of 3
      • Insert a second opening pick into the gap to the left of the first pick.
      • Slide the opening pick back towards the left side of the device.
      • Leave the opening pick inserted.
      Ask FixBot
    21. Nintendo Switch Front Frame Replacement: step 63, image 1 of 1
      • Heat the left edge of the screen for around two minutes to help soften the adhesive.
      Ask FixBot
    22. Nintendo Switch Front Frame Replacement: step 64, image 1 of 3 Nintendo Switch Front Frame Replacement: step 64, image 2 of 3 Nintendo Switch Front Frame Replacement: step 64, image 3 of 3
      • Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
      Ask FixBot
    23. Nintendo Switch Front Frame Replacement: step 65, image 1 of 2 Nintendo Switch Front Frame Replacement: step 65, image 2 of 2
      • Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
      Ask FixBot
    24. Nintendo Switch Front Frame Replacement: step 66, image 1 of 1
      • Heat the top edge of the screen for around two minutes to help soften the adhesive.
      Ask FixBot
    25. Nintendo Switch Front Frame Replacement: step 67, image 1 of 3 Nintendo Switch Front Frame Replacement: step 67, image 2 of 3 Nintendo Switch Front Frame Replacement: step 67, image 3 of 3
      • Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
      Ask FixBot
    26. Nintendo Switch Front Frame Replacement: step 68, image 1 of 3 Nintendo Switch Front Frame Replacement: step 68, image 2 of 3 Nintendo Switch Front Frame Replacement: step 68, image 3 of 3
      • Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
      Ask FixBot
    27. Nintendo Switch Front Frame Replacement: step 69, image 1 of 3 Nintendo Switch Front Frame Replacement: step 69, image 2 of 3 Nintendo Switch Front Frame Replacement: step 69, image 3 of 3
      • Heat the right edge of the screen for around two minutes to help soften the adhesive.
      • Place the flat end of a spudger into the gap along the left edge of the screen.
      • Carefully and slowly lift the left edge of the screen, opening it like a book.
      Ask FixBot
    28. Nintendo Switch Front Frame Replacement: step 70, image 1 of 3 Nintendo Switch Front Frame Replacement: step 70, image 2 of 3 Nintendo Switch Front Frame Replacement: step 70, image 3 of 3
      • Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
      • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
      • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
      Ask FixBot
    29. Nintendo Switch Front Frame Replacement, Remove the Front Frame: step 71, image 1 of 1
      • Remove the four screws securing the front frame to the midframe.
      Ask FixBot
    30. Nintendo Switch Front Frame Replacement: step 72, image 1 of 3 Nintendo Switch Front Frame Replacement: step 72, image 2 of 3 Nintendo Switch Front Frame Replacement: step 72, image 3 of 3
      • Lift the front edge of the frame then slide the frame up toward the top of the display to remove it.
      Ask FixBot
29 other people completed this guide.
Author
with
Jerry Wheeler
103,496 Reputation
97 Guides authored
4 Guide Comments
What kind of adhesive is originally used and where to buy? don't really want to use tape...
GBG HNM - Reply Share
Depending where you are, this vendor is selling precut adhesive for the screen to frame.
https://www.repairsuniverse.com/products...
Jerry Wheeler - Reply Share
The guide does not mention how to remove the battery! Only how to unplug it!
Carson Froelich - Reply Share
That's because the battery does not need to be removed for this procedure.
The photos were taken during a midframe replacement where the battery had already been removed, which is why I placed a note at the beginning of the guide stating:
Past 24 Hours: 24
Past 7 Days: 138
Past 30 Days: 672
All Time: 40,210
