Nintendo Switch Exterior Power and Volume Button Replacement
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the back-side screws: step 3, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Ask FixBot
    4. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the top and bottom screws: step 4, image 2 of 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Ask FixBot
    5. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the center side screws: step 5, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the center side screws: step 5, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Ask FixBot
    6. Nintendo Switch Exterior Power and Volume Button Replacement: step 6, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 6, image 2 of 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Ask FixBot
    7. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the kickstand well screw: step 7, image 1 of 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Ask FixBot
    8. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: step 8, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: step 8, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the rear panel: step 8, image 3 of 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the microSD card reader: step 9, image 1 of 1
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 10, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 10, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 10, image 3 of 3
      • Use the flat end of a spudger to disconnect the microSD card reader press connector and lift straight up to remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement, Reassembly information: step 11, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Reassembly information: step 11, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement, Reassembly information: step 11, image 3 of 3
      • During reassembly:
      • Peel the foam block off the MicroSD card reader.
      • Carefully align the MicroSD card reader press connector over its socket on the board and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Set the foam block onto the connector and press it into place.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the shield plate: step 12, image 1 of 1
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 13, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 13, image 2 of 2
      Buy
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement: step 14, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 14, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 14, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Disconnect the battery: step 15, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Disconnect the battery: step 15, image 2 of 2
      • Insert the point of a spudger beneath the battery cable and slowly lift straight up to disconnect the flat‑topped battery connector from the board.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the heat sink: step 16, image 1 of 1
      • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    2. Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      • The foam is really delicate and tears easily. Use the following technique to peel the foam:
      • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
      • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
      • Press the top of the foam with your finger to hold it in place.
      • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement: step 18, image 1 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 18, image 2 of 3 Nintendo Switch Exterior Power and Volume Button Replacement: step 18, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
      • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the headphone jack and game card reader: step 19, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the headphone jack and game card reader: step 19, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 20, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 20, image 2 of 2
      Buy
      • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
      • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
      • With the cable parallel to the board, gently slide it into its connector.
      • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
      • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement: step 21, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 21, image 2 of 2
      • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
      Ask FixBot
    4. Nintendo Switch Exterior Power and Volume Button Replacement: step 22, image 1 of 1
      • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
      Ask FixBot
    5. Nintendo Switch Exterior Power and Volume Button Replacement: step 23, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 23, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
      Ask FixBot
    6. Nintendo Switch Exterior Power and Volume Button Replacement: step 24, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Remove the fan: step 25, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Remove the fan: step 25, image 2 of 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 26, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 26, image 2 of 2
      Buy
      • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement: step 27, image 1 of 1
      • Use a JIS 00 driver to remove the three 4.8 mm screws securing the fan.
      Ask FixBot
    4. Nintendo Switch Exterior Power and Volume Button Replacement: step 28, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 28, image 2 of 2
      • Use a pair of tweezers or your fingers to lift the fan straight up and remove it from the device.
      • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the rubber bushings) to the new part before installing.
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Power and Volume Button Board: step 29, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement, Power and Volume Button Board: step 29, image 2 of 2
      • Use a spudger to flip up the small black locking flap on the power/volume ribbon cable ZIF connector.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 30, image 1 of 1
      • Use the flat end of a spudger to pry up the taped down power/volume ribbon cable.
      Ask FixBot
    3. Nintendo Switch Exterior Power and Volume Button Replacement: step 31, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 31, image 2 of 2
      Buy
      Ask FixBot
    1. Nintendo Switch Exterior Power and Volume Button Replacement, Exterior Power and Volume Buttons: step 32, image 1 of 1
      Buy
      • Pull the rubber conductive pad out with a pair of blunt nose tweezers.
      Ask FixBot
    2. Nintendo Switch Exterior Power and Volume Button Replacement: step 33, image 1 of 2 Nintendo Switch Exterior Power and Volume Button Replacement: step 33, image 2 of 2
      • Pull the power and volume buttons out with a pair of blunt nose tweezers.
      Ask FixBot
11 other people completed this guide.
Blake Klein
75,435 Reputation
50 Guides authored
3 Guide Comments
What happens if the small black locking flap breaks?
James Funderburk - Reply Share
Two angles are congruent if they have the same measure. You already know that when two lines intersect the vertical angles formed are congruent. You have also seen that if ∠A and ∠B are each complementary to ∠C, then ∠A ~= ∠B. There are other angle relationships to explore. When you expose these angle relationships, you will establish their truth using a formal proof.
Qui Ma - Reply Share
This guide is missing the steps to Remove the microSD card reader and the steps to Remove the headphone jack and game card reader
Jesue Agosto - Reply Share
Past 24 Hours: 12
Past 7 Days: 61
Past 30 Days: 201
All Time: 20,369
