Nintendo Switch 2 Headphone Jack Replacement
  1. Nintendo Switch 2 Headphone Jack Replacement, Power off the console: step 1, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Power off the console: step 1, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Power off the console: step 1, image 3 of 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
    Ask FixBot
  2. Nintendo Switch 2 Headphone Jack Replacement, Remove the bottom screws: step 2, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the bottom screws: step 2, image 2 of 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    Ask FixBot
  3. Nintendo Switch 2 Headphone Jack Replacement, Remove the top screw: step 3, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the top screw: step 3, image 2 of 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
    Ask FixBot
  4. Nintendo Switch 2 Headphone Jack Replacement, Heat the right side sticker: step 4, image 1 of 1
    • The Switch 2 has stickers on either side that need to be removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
    Ask FixBot
  5. Nintendo Switch 2 Headphone Jack Replacement, Pry up the right side sticker: step 5, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Pry up the right side sticker: step 5, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Pry up the right side sticker: step 5, image 3 of 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
    Ask FixBot
  6. Nintendo Switch 2 Headphone Jack Replacement: step 6, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 6, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 6, image 3 of 3
    Tool used on this step:
    Jimmy
    $7.95
    Buy
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
    Ask FixBot
  7. Nintendo Switch 2 Headphone Jack Replacement, Heat the right side sticker: step 7, image 1 of 1
    • Reheat the bottom of the right side until it's hot to the touch.
    Ask FixBot
  8. Nintendo Switch 2 Headphone Jack Replacement, Remove the right side sticker: step 8, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the right side sticker: step 8, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the right side sticker: step 8, image 3 of 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
    Ask FixBot
  9. Nintendo Switch 2 Headphone Jack Replacement, Remove the left side sticker: step 9, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the left side sticker: step 9, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the left side sticker: step 9, image 3 of 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
    Ask FixBot
  10. Nintendo Switch 2 Headphone Jack Replacement, Remove the side screws: step 10, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the side screws: step 10, image 2 of 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Ask FixBot
  11. Nintendo Switch 2 Headphone Jack Replacement, Open the kickstand: step 11, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Open the kickstand: step 11, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Open the kickstand: step 11, image 3 of 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
    Ask FixBot
  12. Nintendo Switch 2 Headphone Jack Replacement, Remove the back-side screws: step 12, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the back-side screws: step 12, image 2 of 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
    Ask FixBot
  13. Nintendo Switch 2 Headphone Jack Replacement, Insert an opening pick: step 13, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Insert an opening pick: step 13, image 2 of 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
    Ask FixBot
  14. Nintendo Switch 2 Headphone Jack Replacement: step 14, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 14, image 2 of 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
    Ask FixBot
  15. Nintendo Switch 2 Headphone Jack Replacement, Insert a second opening pick: step 15, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Insert a second opening pick: step 15, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Insert a second opening pick: step 15, image 3 of 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
    Ask FixBot
  16. Nintendo Switch 2 Headphone Jack Replacement: step 16, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 16, image 2 of 2
    • Slide the first opening pick back to where it was first inserted.
    Ask FixBot
  17. Nintendo Switch 2 Headphone Jack Replacement, Remove the back cover: step 17, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the back cover: step 17, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Remove the back cover: step 17, image 3 of 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
    Ask FixBot
  18. Nintendo Switch 2 Headphone Jack Replacement: step 18, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 18, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 18, image 3 of 3
    • Lift the back cover up from the bottom edge and remove it.
    Ask FixBot
  19. Nintendo Switch 2 Headphone Jack Replacement, Remove the lower antenna screws: step 19, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the lower antenna screws: step 19, image 2 of 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
    Ask FixBot
  20. Nintendo Switch 2 Headphone Jack Replacement, Remove the lower antenna: step 20, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the lower antenna: step 20, image 2 of 2
    • Use tweezers or your fingers to remove the lower antenna.
    Ask FixBot
  21. Nintendo Switch 2 Headphone Jack Replacement, Remove the upper antenna screws: step 21, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the upper antenna screws: step 21, image 2 of 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
    Ask FixBot
  22. Nintendo Switch 2 Headphone Jack Replacement, Remove the upper antenna: step 22, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the upper antenna: step 22, image 2 of 2
    • Use tweezers or your fingers to remove the upper antenna.
    Ask FixBot
  23. Nintendo Switch 2 Headphone Jack Replacement, Disconnect the lower antenna cable: step 23, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the lower antenna cable: step 23, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the lower antenna cable: step 23, image 3 of 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
    Ask FixBot
  24. Nintendo Switch 2 Headphone Jack Replacement, Disconnect the remaining antenna cables: step 24, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the remaining antenna cables: step 24, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the remaining antenna cables: step 24, image 3 of 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
    Ask FixBot
  25. Nintendo Switch 2 Headphone Jack Replacement, Disconnect the MicroSD connector: step 25, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the MicroSD connector: step 25, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the MicroSD connector: step 25, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
    Ask FixBot
  26. Nintendo Switch 2 Headphone Jack Replacement, Remove the shield plate screws: step 26, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the shield plate screws: step 26, image 2 of 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
    Ask FixBot
  27. Nintendo Switch 2 Headphone Jack Replacement, Lift the shield plate: step 27, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Lift the shield plate: step 27, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Lift the shield plate: step 27, image 3 of 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
    Ask FixBot
  28. Nintendo Switch 2 Headphone Jack Replacement: step 28, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 28, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 28, image 3 of 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
    Ask FixBot
  29. Nintendo Switch 2 Headphone Jack Replacement, Unroute the gray antenna cable: step 29, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Unroute the gray antenna cable: step 29, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Unroute the gray antenna cable: step 29, image 3 of 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
    Ask FixBot
  30. Nintendo Switch 2 Headphone Jack Replacement: step 30, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 30, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 30, image 3 of 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
    Ask FixBot
  31. Nintendo Switch 2 Headphone Jack Replacement: step 31, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 31, image 2 of 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
    Ask FixBot
  32. Nintendo Switch 2 Headphone Jack Replacement, Remove the shield plate: step 32, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the shield plate: step 32, image 2 of 2
    • Pick up and remove the shield plate.
    Ask FixBot
  33. Nintendo Switch 2 Headphone Jack Replacement, Disconnect the battery: step 33, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Disconnect the battery: step 33, image 2 of 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
    Ask FixBot
  34. Nintendo Switch 2 Headphone Jack Replacement, Clean the heat pipe: step 34, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Clean the heat pipe: step 34, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Clean the heat pipe: step 34, image 3 of 3
    Arctic Silver ArctiClean
    $11.99
    Buy
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
    Ask FixBot
  35. Nintendo Switch 2 Headphone Jack Replacement, Remove the headphone jack: step 35, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Remove the headphone jack: step 35, image 2 of 2
    • Use the point of a spudger to flip up the locking flap on the headphone jack ZIF connector, located on the top edge of the console's board.
    Ask FixBot
  36. Nintendo Switch 2 Headphone Jack Replacement: step 36, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 36, image 2 of 2
    • Use a JIS 00 driver to remove the 6.2 mm‑long silver screw securing the headphone jack.
    Ask FixBot
  37. Nintendo Switch 2 Headphone Jack Replacement: step 37, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 37, image 2 of 2
    • Pick up the headphone jack assembly and pull its cable straight out of its connector to remove it.
    Ask FixBot
  38. Nintendo Switch 2 Headphone Jack Replacement, Disassembly complete: step 38, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Ask FixBot
  39. Nintendo Switch 2 Headphone Jack Replacement, Install the headphone jack: step 39, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Install the headphone jack: step 39, image 2 of 2
    • Align the headphone jack assembly with its ZIF connector on the board.
    • Guide the cable into its connector, then set the headphone jack into its recess in the frame.
    Ask FixBot
  40. Nintendo Switch 2 Headphone Jack Replacement: step 40, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 40, image 2 of 2
    • Use a JIS 00 driver to install the 6.2 mm‑long silver screw securing the headphone jack.
    Ask FixBot
  41. Nintendo Switch 2 Headphone Jack Replacement: step 41, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 41, image 2 of 2
    • Flip the hinged locking flap down to secure the headphone jack cable.
    Ask FixBot
  42. Nintendo Switch 2 Headphone Jack Replacement, Connect the battery: step 42, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Connect the battery: step 42, image 2 of 2
    • Align the battery connector over its socket on the board.
    • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
    Ask FixBot
  43. Nintendo Switch 2 Headphone Jack Replacement, Apply thermal putty: step 43, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Apply thermal putty: step 43, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Apply thermal putty: step 43, image 3 of 3
    iFixit Thermal Putty
    $9.95
    Buy
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
    Ask FixBot
  44. Nintendo Switch 2 Headphone Jack Replacement, Route the gray antenna cable: step 44, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Route the gray antenna cable: step 44, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Route the gray antenna cable: step 44, image 3 of 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
    Ask FixBot
  45. Nintendo Switch 2 Headphone Jack Replacement, Lower the shield plate: step 45, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Lower the shield plate: step 45, image 2 of 2
    • Lower the shield plate into place and align it with its screw holes.
    Ask FixBot
  46. Nintendo Switch 2 Headphone Jack Replacement, Finish routing the gray antenna cable: step 46, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Finish routing the gray antenna cable: step 46, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Finish routing the gray antenna cable: step 46, image 3 of 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
    Ask FixBot
  47. Nintendo Switch 2 Headphone Jack Replacement: step 47, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 47, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 47, image 3 of 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
    Ask FixBot
  48. Nintendo Switch 2 Headphone Jack Replacement, Install the shield plate screws: step 48, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Install the shield plate screws: step 48, image 2 of 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
    Ask FixBot
  49. Nintendo Switch 2 Headphone Jack Replacement, Connect the MicroSD connector: step 49, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Connect the MicroSD connector: step 49, image 2 of 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Ask FixBot
  50. Nintendo Switch 2 Headphone Jack Replacement, Connect the antenna cables: step 50, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Connect the antenna cables: step 50, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Connect the antenna cables: step 50, image 3 of 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
    Ask FixBot
  51. Nintendo Switch 2 Headphone Jack Replacement, Install the upper antenna: step 51, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the upper antenna: step 51, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the upper antenna: step 51, image 3 of 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
    Ask FixBot
  52. Nintendo Switch 2 Headphone Jack Replacement, Install the lower antenna: step 52, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the lower antenna: step 52, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the lower antenna: step 52, image 3 of 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
    Ask FixBot
  53. Nintendo Switch 2 Headphone Jack Replacement, Prepare the back cover: step 53, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Prepare the back cover: step 53, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Prepare the back cover: step 53, image 3 of 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
    Ask FixBot
  54. Nintendo Switch 2 Headphone Jack Replacement, Install the back cover: step 54, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the back cover: step 54, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the back cover: step 54, image 3 of 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
    Ask FixBot
  55. Nintendo Switch 2 Headphone Jack Replacement: step 55, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement: step 55, image 2 of 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
    Ask FixBot
  56. Nintendo Switch 2 Headphone Jack Replacement, Install the back-side screws: step 56, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the back-side screws: step 56, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the back-side screws: step 56, image 3 of 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
    Ask FixBot
  57. Nintendo Switch 2 Headphone Jack Replacement, Install the side screws: step 57, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Install the side screws: step 57, image 2 of 2
    • Use a JIS 00 driver to install the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Ask FixBot
  58. Nintendo Switch 2 Headphone Jack Replacement, Test the console: step 58, image 1 of 2 Nintendo Switch 2 Headphone Jack Replacement, Test the console: step 58, image 2 of 2
    • Power on the console and test functionality to ensure it's working as expected.
    Ask FixBot
  59. Nintendo Switch 2 Headphone Jack Replacement, Install the stickers: step 59, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the stickers: step 59, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement, Install the stickers: step 59, image 3 of 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
    Ask FixBot
  60. Nintendo Switch 2 Headphone Jack Replacement: step 60, image 1 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 60, image 2 of 3 Nintendo Switch 2 Headphone Jack Replacement: step 60, image 3 of 3
    • Repeat this procedure to install the left side sticker.
    Ask FixBot
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
58,297 Reputation
316 Guides authored
1 Guide Comment
Do you know where i can aquire the part if the headphone hardware that is actually soldered to the motherboard. Mine appears to be melted.
Nathan D - Reply Share
Past 24 Hours: 6
Past 7 Days: 89
Past 30 Days: 223
All Time: 1,189
