Nintendo Super Famicom SHVC-001 Controller Port Board Replacement
  1. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Upper Case: step 1, image 1 of 1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
    Ask FixBot
  2. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 2, image 1 of 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 2, image 2 of 2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
    Ask FixBot
  3. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: step 3, image 1 of 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: step 3, image 2 of 2
    • Carefully disconnect the ribbon cable that is attached to the controller board and the main board.
    Ask FixBot
  4. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 4, image 1 of 1
    • Lift the controller port board directly up and out of the chassis.
    • If your new controller port board does not come with a ribbon cable, you will also need to replace that.
    Ask FixBot
  5. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 5, image 1 of 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 5, image 2 of 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: step 5, image 3 of 3
    • The next bullet demonstrates how to replace your ribbon cable.
    • Disconnect and remove the old cable and replace it with a new 1.25 mm ribbon cable.
    Ask FixBot
1 Guide Comment
The B button only works but the rest of the controller is not pressing. Can you help?
Maximus Sampaio Costa - Reply Share
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 55
All Time: 938
