Nintendo NES Advantage Start Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
67
All Time:
664
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Nintendo NES Advantage Model NES-026 Start Button is not being responsive to being pressed, although plugged into NES, you may need to replace the Start Button, using this guide.
The Start Button is an input sensory button used for starting and pausing the game.
Tools
    1. Nintendo NES Advantage Start Button Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four sticky pads from the bottom of the device.
      • If the pads are stuck, use a spudger to remove them.
      Ask FixBot
    2. Nintendo NES Advantage Start Button Replacement: step 2, image 1 of 2 Nintendo NES Advantage Start Button Replacement: step 2, image 2 of 2
      • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
      • Use your hands to pull the back panel away from the controller.
      Ask FixBot
    1. Nintendo NES Advantage Start Button Replacement, Circuit Board: step 3, image 1 of 2 Nintendo NES Advantage Start Button Replacement, Circuit Board: step 3, image 2 of 2
      • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
      • Lift the gray component away from the device.
      Ask FixBot
    2. Nintendo NES Advantage Start Button Replacement: step 4, image 1 of 1
      • Lift up the black wire and move it to the side.
      Ask FixBot
    3. Nintendo NES Advantage Start Button Replacement: step 5, image 1 of 3 Nintendo NES Advantage Start Button Replacement: step 5, image 2 of 3 Nintendo NES Advantage Start Button Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the two silver knobs on the front of the device.
      • Unscrew the two silver nuts using a flathead screwdriver.
      • Remove each silver nut and silver washer using a pair of tweezers.
      Ask FixBot
    4. Nintendo NES Advantage Start Button Replacement: step 6, image 1 of 2 Nintendo NES Advantage Start Button Replacement: step 6, image 2 of 2
      • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
      • Remove the silver bracket from the top of the circuit board.
      Ask FixBot
    5. Nintendo NES Advantage Start Button Replacement: step 7, image 1 of 1
      • Remove the circuit board from the controller.
      Ask FixBot
    1. Nintendo NES Advantage Start Button Replacement, Start Button: step 8, image 1 of 1
      • Remove Start Button.
      Ask FixBot
Sylvia Pena
79 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 67
All Time: 664
