Nintendo NES Advantage Joystick Replacement
  1. Nintendo NES Advantage Joystick Replacement, Back Panel: step 1, image 1 of 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
    Ask FixBot
  2. Nintendo NES Advantage Joystick Replacement: step 2, image 1 of 2 Nintendo NES Advantage Joystick Replacement: step 2, image 2 of 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
    Ask FixBot
  3. Nintendo NES Advantage Joystick Replacement, Joystick Panel: step 3, image 1 of 1
    • Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
    • While removing the last (fourth) screw, apply downward pressure on the panel. This will make it easier to remove the last screw because of the joystick spring on the other side of this panel.
    Ask FixBot
  4. Nintendo NES Advantage Joystick Replacement: step 4, image 1 of 2 Nintendo NES Advantage Joystick Replacement: step 4, image 2 of 2
    • Remove the small square panel.
    • This panel is connected with wires to the main circuit board. To replace the joystick panel, you will need to desolder the wires. To learn more about soldering, refer to our How To Solder and Desolder Connections guide.
    Ask FixBot
  5. Nintendo NES Advantage Joystick Replacement, Joystick: step 5, image 1 of 2 Nintendo NES Advantage Joystick Replacement, Joystick: step 5, image 2 of 2
    • Using your hands, unscrew the ball on top of the joystick.
    Ask FixBot
  6. Nintendo NES Advantage Joystick Replacement: step 6, image 1 of 1
    • Pull the joystick through the back of the NES Advantage Gamepad.
    Ask FixBot
Kristen Gismondi
107,737 Reputation
270 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,612 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 820
