Nintendo NES Advantage A Button Replacement
    1. Nintendo NES Advantage A Button Replacement, Back Panel: step 1, image 1 of 1
      • Remove the four sticky pads from the bottom of the device.
      • If the pads are stuck, use a spudger to remove them.
      Ask FixBot
    2. Nintendo NES Advantage A Button Replacement: step 2, image 1 of 2 Nintendo NES Advantage A Button Replacement: step 2, image 2 of 2
      • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
      • Use your hands to pull the back panel away from the controller.
      Ask FixBot
    1. Nintendo NES Advantage A Button Replacement, Circuit Board: step 3, image 1 of 2 Nintendo NES Advantage A Button Replacement, Circuit Board: step 3, image 2 of 2
      • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
      • Lift the gray component away from the device.
      Ask FixBot
    2. Nintendo NES Advantage A Button Replacement: step 4, image 1 of 1
      • Lift up the black wire and move it to the side.
      Ask FixBot
    3. Nintendo NES Advantage A Button Replacement: step 5, image 1 of 3 Nintendo NES Advantage A Button Replacement: step 5, image 2 of 3 Nintendo NES Advantage A Button Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the two silver knobs on the front of the device.
      • Unscrew the two silver nuts using a flathead screwdriver.
      • Remove each silver nut and silver washer using a pair of tweezers.
      Ask FixBot
    4. Nintendo NES Advantage A Button Replacement: step 6, image 1 of 2 Nintendo NES Advantage A Button Replacement: step 6, image 2 of 2
      • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
      • Remove the silver bracket from the top of the circuit board.
      Ask FixBot
    5. Nintendo NES Advantage A Button Replacement: step 7, image 1 of 1
      • Remove the circuit board from the controller.
      Ask FixBot
    1. Nintendo NES Advantage A Button Replacement, A Button: step 8, image 1 of 1
      • Remove the A Button from the case.
      Ask FixBot
1 Guide Comment
You can use a 10 mm socket wrench for the silver nuts behind the gray knobs ( step 5)
Electronic Cartel - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 35
All Time: 964
