Up to 20% off select tools
Nintendo GameCube Motherboard Replacement
Views: 41K
View statistics:
Past 24 Hours:
9
Past 7 Days:
66
Past 30 Days:
335
All Time:
41,029
Comments: 17
14 comments on steps, 3 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to remove the existing GameCube motherboard and replace it with a new one.
    1. Nintendo GameCube Motherboard Replacement, Top Case: step 1, image 1 of 3 Nintendo GameCube Motherboard Replacement, Top Case: step 1, image 2 of 3 Nintendo GameCube Motherboard Replacement, Top Case: step 1, image 3 of 3
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
      Ask FixBot
    2. Nintendo GameCube Motherboard Replacement: step 2, image 1 of 3 Nintendo GameCube Motherboard Replacement: step 2, image 2 of 3 Nintendo GameCube Motherboard Replacement: step 2, image 3 of 3
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
      Ask FixBot
    1. Nintendo GameCube Motherboard Replacement, Removing the back panel: step 3, image 1 of 1
      • Gently press down on the clips located on either side of the back panel.
      • Carefully remove the back panel from the GameCube.
      Ask FixBot
    2. Nintendo GameCube Motherboard Replacement: step 4, image 1 of 1
      • Unclip the controller ports at the front of the unit.
      • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
      • Controller ports are where the controllers plug into the game console, and are a half circular shape.
      Ask FixBot
    3. Nintendo GameCube Motherboard Replacement, Separate the casing: step 5, image 1 of 2 Nintendo GameCube Motherboard Replacement, Separate the casing: step 5, image 2 of 2
      • This step may not be necessary depending on your end goal
      • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
      • Carefully separate the gray outer casing of the control port and the circuit board.
      Ask FixBot
    1. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: step 6, image 1 of 2 Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: step 6, image 2 of 2
      • The left side of the unit contains the cooling fan and its housing.
      • Carefully remove the two screws attaching the cooling fan housing to the unit.
      • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
      Ask FixBot
    2. Nintendo GameCube Motherboard Replacement: step 7, image 1 of 2 Nintendo GameCube Motherboard Replacement: step 7, image 2 of 2
      • Remove the four Phillips #1 screws retaining the ground springs.
      • Carefully remove the ground springs from the main unit.
      Ask FixBot
    3. Nintendo GameCube Motherboard Replacement: step 8, image 1 of 2 Nintendo GameCube Motherboard Replacement: step 8, image 2 of 2
      • The optical drive is secured to a metal plate.
      • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
      Ask FixBot
    4. Nintendo GameCube Motherboard Replacement, Remove the assembly: step 9, image 1 of 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: step 9, image 2 of 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: step 9, image 3 of 3
      • Carefully separate the optical drive assembly from the rest of the GameCube unit.
      • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
      • The metal plate and the actual optical drive will remain attached.
      Ask FixBot
    1. Nintendo GameCube Motherboard Replacement, Motherboard: step 10, image 1 of 2 Nintendo GameCube Motherboard Replacement, Motherboard: step 10, image 2 of 2
      • With the Optical Drive Assembly removed, your GameCube should now look like this.
      • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
      Ask FixBot
    2. Nintendo GameCube Motherboard Replacement: step 11, image 1 of 2 Nintendo GameCube Motherboard Replacement: step 11, image 2 of 2
      • Gently lift the motherboard from base (as shown in second picture).
      Ask FixBot
    3. Nintendo GameCube Motherboard Replacement: step 12, image 1 of 2 Nintendo GameCube Motherboard Replacement: step 12, image 2 of 2
      • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
      • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
      Ask FixBot
17 other people completed this guide.
Author
with
mwbisson
1,176 Reputation
3 Guides authored
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Members
96 Guides authored
3 Guide Comments
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - Reply Share
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone - Reply Share
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - Reply Share
Past 24 Hours: 9
Past 7 Days: 66
Past 30 Days: 335
All Time: 41,029
