Up to 20% off select tools
Nintendo GameCube Front and Back Panel Replacement
Views: 20K
View statistics:
Past 24 Hours:
7
Past 7 Days:
45
Past 30 Days:
205
All Time:
19,923
Comments: 9
9 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing these panels allows further access to the GameCube's components.
    1. Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 1 of 3 Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 2 of 3 Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 3 of 3
      • Turn over the Gamecube so that the bottom side is facing up.
      • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
      Ask FixBot
    2. Nintendo GameCube Front and Back Panel Replacement: step 2, image 1 of 3 Nintendo GameCube Front and Back Panel Replacement: step 2, image 2 of 3 Nintendo GameCube Front and Back Panel Replacement: step 2, image 3 of 3
      • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
      • Move the GameCube so that the inside is facing upwards.
      Ask FixBot
    1. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: step 3, image 1 of 1
      • Gently press down on the clips located on either side of the back panel.
      • Carefully remove the back panel from the GameCube.
      Ask FixBot
    2. Nintendo GameCube Front and Back Panel Replacement: step 4, image 1 of 1
      • Unclip the controller ports at the front of the unit.
      • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
      • Controller ports are where the controllers plug into the game console, and are a half circular shape.
      Ask FixBot
    3. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: step 5, image 1 of 2 Nintendo GameCube Front and Back Panel Replacement, Separate the casing: step 5, image 2 of 2
      • This step may not be necessary depending on your end goal
      • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
      • Carefully separate the gray outer casing of the control port and the circuit board.
      Ask FixBot
6 other people completed this guide.
Author
with
dcarlin
399 Reputation
4 Guides authored
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 205
All Time: 19,923
