Nintendo GameCube Controller Joystick Replacement
Views: 112K
View statistics:
Past 24 Hours:
15
Past 7 Days:
115
Past 30 Days:
509
All Time:
111,813
Comments: 20
7 comments on steps, 13 guide comments.
Go to guide comments
Completed: 32
32 people have marked this guide "completed." Will you be next?
Favorites: 20
20 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 6 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will take you through the steps of removing the joystick. This will come in handy if you have a rogue joystick
Tools
    1. Nintendo GameCube Controller Joystick Replacement, Back Panel: step 1, image 1 of 1
      • Place the controller (buttons down) on a solid surface.
      • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
      Ask FixBot
    2. Nintendo GameCube Controller Joystick Replacement: step 2, image 1 of 1
      • Gently lift the back panel up, separating it from the front panel.
      • Some of the buttons may fall out if they are knocked around.
      Ask FixBot
    1. Nintendo GameCube Controller Joystick Replacement, Z Button: step 3, image 1 of 2 Nintendo GameCube Controller Joystick Replacement, Z Button: step 3, image 2 of 2
      • Grab the Z-button by the peg with tweezers and lift it out of the controller.
      • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
      Ask FixBot
    1. Nintendo GameCube Controller Joystick Replacement, Circuit Board: step 4, image 1 of 1
      • Carefully unhook the cable that is looped around the peg.
      Ask FixBot
    2. Nintendo GameCube Controller Joystick Replacement: step 5, image 1 of 1
      • Lift the circuit board out of the controller.
      • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
      Ask FixBot
    1. Nintendo GameCube Controller Joystick Replacement, Joystick: step 6, image 1 of 2 Nintendo GameCube Controller Joystick Replacement, Joystick: step 6, image 2 of 2
      • Grab the base of the grey cover and pull it off.
      • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
      Ask FixBot
32 other people completed this guide.
Sean Michel
2,768 Reputation
8 Guides authored
Cal Poly, Team 19-44, Regan Winter 2013 Member of Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Members
108 Guides authored
13 Guide Comments
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - Reply Share
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - Reply Share
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - Reply Share
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - Reply Share
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT - Reply Share
Past 24 Hours: 15
Past 7 Days: 115
Past 30 Days: 509
All Time: 111,813
