Nintendo Game Boy Advance SP Brightness Switch Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Prepare your Game Boy for disassembly: step 1, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Prepare your Game Boy for disassembly: step 1, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Prepare your Game Boy for disassembly: step 1, image 3 of 3
      • Slide the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge in, remove it.
      Ask FixBot
    2. Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the battery cover: step 2, image 1 of 2 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the battery cover: step 2, image 2 of 2
      • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Nintendo Game Boy Advance SP Brightness Switch Replacement: step 3, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement: step 3, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement: step 3, image 3 of 3
      • Lift the edge of the cover near the screw and remove the cover.
      • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
      Ask FixBot
    4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the battery: step 4, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the battery: step 4, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the battery: step 4, image 3 of 3
      • Use your finger to lift the battery by the tab on its left edge, then remove it.
      • During reassembly:
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      • Your replacement battery may come with a plastic enclosure that slides over the battery.
      • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
      Ask FixBot
    1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the bottom shell: step 5, image 1 of 2 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the bottom shell: step 5, image 2 of 2
      • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
      • Four 6.3 mm‑long recessed screws
      • Two 4.6 mm‑long screws
      Ask FixBot
    2. Nintendo Game Boy Advance SP Brightness Switch Replacement: step 6, image 1 of 2 Nintendo Game Boy Advance SP Brightness Switch Replacement: step 6, image 2 of 2
      • Lift the bottom shell straight up and remove it.
      Ask FixBot
    1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the speaker: step 7, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the speaker: step 7, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the speaker: step 7, image 3 of 3
      • Use the point of a spudger or a clean fingernail to lift the speaker until you can grip it with your fingers.
      • Remove the speaker.
      Ask FixBot
    2. Nintendo Game Boy Advance SP Brightness Switch Replacement, Prop up the main body: step 8, image 1 of 1
      • Remove the circular mesh from the speaker recess and set it aside—the piece can easily fall out and get lost when working.
      Ask FixBot
    3. Nintendo Game Boy Advance SP Brightness Switch Replacement, Prop up the main body: step 9, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Prop up the main body: step 9, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Prop up the main body: step 9, image 3 of 3
      • Be careful not to strain the screen cable during the next few steps—it has very little slack.
      • You need to prop up the main body of your Game Boy in order to disconnect the screen cable without straining it. Here are two ways to do so:
      • Option 1: Open the main body of your Game Boy to a 90‑degree angle and gently lay the motherboard down. Make sure the main body is resting on top of the motherboard to give the cable slack.
      • Option 2: Keep the main body closed and prop it up on the edge of the logic board, using a sturdy object to hold it up.
      Ask FixBot
    4. Nintendo Game Boy Advance SP Brightness Switch Replacement, Disconnect the screen cable: step 10, image 1 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Disconnect the screen cable: step 10, image 2 of 3 Nintendo Game Boy Advance SP Brightness Switch Replacement, Disconnect the screen cable: step 10, image 3 of 3
      • Use the point of a spudger to push the two tabs on either side of the screen cable connector into the unlocked position.
      • Only push the tabs until they stop. If you push them too far, you may slide the locking tab off the connector.
      Ask FixBot
    5. Nintendo Game Boy Advance SP Brightness Switch Replacement: step 11, image 1 of 2 Nintendo Game Boy Advance SP Brightness Switch Replacement: step 11, image 2 of 2
      • Use a pair of tweezers to gently slide the screen cable out of its socket.
      Ask FixBot
    6. Nintendo Game Boy Advance SP Brightness Switch Replacement, Remove the main body: step 12, image 1 of 1
      • Remove the main body from the motherboard.
      • During reassembly, prop up the main body for enough slack reconnect the screen cable.
      Ask FixBot
    1. Nintendo Game Boy Advance SP Brightness Switch Replacement, Brightness Switch: step 13, image 1 of 1
      • With your fingers, lift the track pad out off the brightness switch.
      • Keep the track pad clean. A dirty or dusty track pad will lead to the brightness switch not working when you press it.
      Ask FixBot
    2. Nintendo Game Boy Advance SP Brightness Switch Replacement: step 14, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, lift the brightness switch out of the Game Boy Advance SP.
      Ask FixBot
16 other people completed this guide.
DJ Pantone
2,081 Reputation
4 Guides authored
Cal Poly, Team 17-22, Forte Winter 2013 Member of Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Members
62 Guides authored
1 Guide Comment
Thank you so much
sherzadcemil - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 27
All Time: 21,448
