Introduction
Follow this guide to replace or upgrade a dead or worn out battery in your Nintendo Game Boy Advance SP.
Your Game Boy's lithium-ion battery has a limited lifespan. If your Game Boy Advance SP won't turn on or dies quickly, it may be time to replace the battery.
The Game Boy Advance SP uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
If your battery looks puffy or swollen, take extra precautions.
Slide the power switch to the OFF position and unplug any cables.
If you have a game cartridge in, remove it.
Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
41 other people completed this guide.
6 Guide Comments
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Why so pedantic?
Recommend replacement battery. I didn't see one in the shop for the advance ds.
