Nintendo Entertainment System Game Cartridge Tray Replacement
    1. Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: step 1, image 1 of 2 Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: step 1, image 2 of 2
      • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
      • The screws are recessed about 40 mm.
      • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
      Ask FixBot
    2. Nintendo Entertainment System Game Cartridge Tray Replacement: step 2, image 1 of 2 Nintendo Entertainment System Game Cartridge Tray Replacement: step 2, image 2 of 2
      • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
      • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
      Ask FixBot
    3. Nintendo Entertainment System Game Cartridge Tray Replacement: step 3, image 1 of 3 Nintendo Entertainment System Game Cartridge Tray Replacement: step 3, image 2 of 3 Nintendo Entertainment System Game Cartridge Tray Replacement: step 3, image 3 of 3
      • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
      • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
      • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
      Ask FixBot
    4. Nintendo Entertainment System Game Cartridge Tray Replacement: step 4, image 1 of 2 Nintendo Entertainment System Game Cartridge Tray Replacement: step 4, image 2 of 2
      • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
      • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
      Ask FixBot
11 other people completed this guide.
nicholasweiser
2,790 Reputation
6 Guides authored
Cal Poly, Team 14-40, Forte Fall 2010 Member of Cal Poly, Team 14-40, Forte Fall 2010
CPSU-FORTE-F10S14G40
4 Members
72 Guides authored
1 Guide Comment
I’m looking for a part that latches the tray into place it’s light blue in colour with a groove in it
Tony - Reply Share
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 192
All Time: 18,543
