Up to 20% off select tools
Nintendo Entertainment System Controller Cable Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
135
All Time:
3,584
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is a fairly straight forward repair. Soldering skills are required.
Still possible even if you've only soldered twice in your life and are afraid you'll make a mess of it. You know who you are ;)
    1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: step 1, image 1 of 2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: step 1, image 2 of 2
      • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
      Ask FixBot
    2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: step 2, image 1 of 1
      • Lift the back cover off the controller.
      • Remove the cable from its holders to facilitate PCB removal.
      Ask FixBot
    3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: step 3, image 1 of 1
      • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
      • Desolder the 5 connections and solder in your new cable.
      • Wire colors are printed on the reverse side of the board.
      Ask FixBot
Author
with
themap504
80 Reputation
1 Guide authored
2 Guide Comments
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - Reply Share
Check for continuity from the pins on the plug side with the wires and soldier them in the corresponding spot, i:e if red is power then you soldier it to the power slot on the motherboard and so on. Check if you can find a instruction book on the controller.
Cgull - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 135
All Time: 3,584
