Nintendo DSi XL Stylus Housing Replacement
    1. Nintendo DSi XL Stylus Housing Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement, Battery: step 1, image 2 of 2
      • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
      • Lift the battery cover off the back of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL Stylus Housing Replacement: step 2, image 1 of 1
      • Lift the battery from the DSi XL.
      Ask FixBot
    1. Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: step 3, image 3 of 3
      • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
      Ask FixBot
    2. Nintendo DSi XL Stylus Housing Replacement: step 4, image 1 of 1
      • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
      • Four silver 5.3 mm screws
      • Two black 5.3 mm screws
      • One black 2.5 mm screw
      Ask FixBot
    3. Nintendo DSi XL Stylus Housing Replacement: step 5, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement: step 5, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement: step 5, image 3 of 3
      • Turn the DSi XL over, and open the display.
      • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
      • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
      Ask FixBot
    4. Nintendo DSi XL Stylus Housing Replacement: step 6, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement: step 6, image 2 of 2
      • Close the display and turn the DSi XL over.
      • Lift the lower case from the front edge.
      • Rotate the lower case away from the DSi.
      • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
      Ask FixBot
    5. Nintendo DSi XL Stylus Housing Replacement: step 7, image 1 of 2 Nintendo DSi XL Stylus Housing Replacement: step 7, image 2 of 2
      • Using a spudger, pry the SD card/right shoulder button connector off its socket.
      • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
      Ask FixBot
    1. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: step 8, image 3 of 3
      • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
      • Lift the right shoulder button assembly from the back case.
      • The components of the right shoulder button assembly:
      • Right shoulder button
      • Shoulder button spring
      • Retaining pin
      • Right shoulder button holding panel
      Ask FixBot
    1. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: step 9, image 1 of 1
      • Remove the stylus from its housing on the right side of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL Stylus Housing Replacement: step 10, image 1 of 3 Nintendo DSi XL Stylus Housing Replacement: step 10, image 2 of 3 Nintendo DSi XL Stylus Housing Replacement: step 10, image 3 of 3
      • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
      • Using a spudger, lift the stylus housing off the lower case.
      • Remove the stylus housing from the handheld console.
      Ask FixBot
4 other people completed this guide.
Brett Hartt
132,425 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
122 Members
86,241 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 116
All Time: 9,208
