Nintendo DSi XL Start/Select Buttons Replacement
    1. Nintendo DSi XL Start/Select Buttons Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement, Battery: step 1, image 2 of 2
      • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
      • Lift the battery cover off the back of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL Start/Select Buttons Replacement: step 2, image 1 of 1
      • Lift the battery from the DSi XL.
      Ask FixBot
    1. Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: step 3, image 3 of 3
      • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
      Ask FixBot
    2. Nintendo DSi XL Start/Select Buttons Replacement: step 4, image 1 of 1
      • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
      • Four silver 5.3 mm screws
      • Two black 5.3 mm screws
      • One black 2.5 mm screw
      Ask FixBot
    3. Nintendo DSi XL Start/Select Buttons Replacement: step 5, image 1 of 3 Nintendo DSi XL Start/Select Buttons Replacement: step 5, image 2 of 3 Nintendo DSi XL Start/Select Buttons Replacement: step 5, image 3 of 3
      • Turn the DSi XL over, and open the display.
      • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
      • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
      Ask FixBot
    4. Nintendo DSi XL Start/Select Buttons Replacement: step 6, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 6, image 2 of 2
      • Close the display and turn the DSi XL over.
      • Lift the lower case from the front edge.
      • Rotate the lower case away from the DSi.
      • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
      Ask FixBot
    5. Nintendo DSi XL Start/Select Buttons Replacement: step 7, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 7, image 2 of 2
      • Using a spudger, pry the SD card/right shoulder button connector off its socket.
      • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
      Ask FixBot
    1. Nintendo DSi XL Start/Select Buttons Replacement, Motherboard: step 8, image 1 of 1
      • Use a spudger to pry the microphone cable off the motherboard.
      • Pry from underneath the cable.
      Ask FixBot
    2. Nintendo DSi XL Start/Select Buttons Replacement: step 9, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 9, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
      • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
      Ask FixBot
    3. Nintendo DSi XL Start/Select Buttons Replacement: step 10, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 10, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
      • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
      Ask FixBot
    4. Nintendo DSi XL Start/Select Buttons Replacement: step 11, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 11, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
      • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
      Ask FixBot
    5. Nintendo DSi XL Start/Select Buttons Replacement: step 12, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 12, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
      • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
      Ask FixBot
    6. Nintendo DSi XL Start/Select Buttons Replacement: step 13, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 13, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
      • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
      Ask FixBot
    7. Nintendo DSi XL Start/Select Buttons Replacement: step 14, image 1 of 1
      • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
      Ask FixBot
    8. Nintendo DSi XL Start/Select Buttons Replacement: step 15, image 1 of 1
      • Remove the screws securing the motherboard to the upper case:
      • A single 2.5 mm silver Phillips screw
      • Four 3.7 mm black Phillips screws
      Ask FixBot
    9. Nintendo DSi XL Start/Select Buttons Replacement: step 16, image 1 of 1
      • Deroute the microphone and antenna cables through the slot in the motherboard.
      Ask FixBot
    10. Nintendo DSi XL Start/Select Buttons Replacement: step 17, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 17, image 2 of 2
      • Rotate the motherboard off the lower case.
      • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
      Ask FixBot
    11. Nintendo DSi XL Start/Select Buttons Replacement: step 18, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 18, image 2 of 2
      • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
      • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
      • The motherboard is now free from the upper case.
      Ask FixBot
    1. Nintendo DSi XL Start/Select Buttons Replacement, Start/Select Buttons: step 19, image 1 of 1
      • Lift the rubber pad off the back of the start/select buttons.
      Ask FixBot
    2. Nintendo DSi XL Start/Select Buttons Replacement: step 20, image 1 of 2 Nintendo DSi XL Start/Select Buttons Replacement: step 20, image 2 of 2
      • Open the display slightly and push the start and select buttons up through the upper case.
      • Remove the start/select buttons from the DSi XL.
      Ask FixBot
3 other people completed this guide.
Brett Hartt
132,360 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 58
All Time: 5,449
