Nintendo DSi XL Speakers Replacement
    1. Nintendo DSi XL Speakers Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Speakers Replacement, Battery: step 1, image 2 of 2
      • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
      • Lift the battery cover off the back of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL Speakers Replacement: step 2, image 1 of 1
      • Lift the battery from the DSi XL.
      Ask FixBot
    1. Nintendo DSi XL Speakers Replacement, Rear Bezel: step 3, image 1 of 3 Nintendo DSi XL Speakers Replacement, Rear Bezel: step 3, image 2 of 3 Nintendo DSi XL Speakers Replacement, Rear Bezel: step 3, image 3 of 3
      • Use a push pin to remove the four plastic screw covers on the front bezel.
      Ask FixBot
    2. Nintendo DSi XL Speakers Replacement: step 4, image 1 of 1
      • Remove four Phillips screws securing the front bezel to the rear bezel.
      Ask FixBot
    3. Nintendo DSi XL Speakers Replacement: step 5, image 1 of 2 Nintendo DSi XL Speakers Replacement: step 5, image 2 of 2
      • Using two hands, gently slide the rear bezel upwards.
      • The rear bezel will move only about 2 mm.
      Ask FixBot
    4. Nintendo DSi XL Speakers Replacement: step 6, image 1 of 2 Nintendo DSi XL Speakers Replacement: step 6, image 2 of 2
      • Insert a spudger into the gap between the front and rear bezel
      • Rotate the spudger away from the DSi XL, prying the two bezels apart.
      Ask FixBot
    5. Nintendo DSi XL Speakers Replacement: step 7, image 1 of 1
      • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
      Ask FixBot
    6. Nintendo DSi XL Speakers Replacement: step 8, image 1 of 1
      • Separate the rear bezel from the front bezel.
      • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
      Ask FixBot
    7. Nintendo DSi XL Speakers Replacement: step 9, image 1 of 1
      • Use the flat end of a spudger to pry the rear camera off the rear bezel.
      • Remove the rear bezel.
      Ask FixBot
    1. Nintendo DSi XL Speakers Replacement, Speakers: step 10, image 1 of 1
      • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
      Ask FixBot
    2. Nintendo DSi XL Speakers Replacement: step 11, image 1 of 1
      • Use a spudger to lift the right speaker from its housing in the front bezel.
      Ask FixBot
    3. Nintendo DSi XL Speakers Replacement: step 12, image 1 of 1
      • Use a spudger to lift the left speaker from its housing in the front bezel.
      Ask FixBot
    4. Nintendo DSi XL Speakers Replacement: step 13, image 1 of 2 Nintendo DSi XL Speakers Replacement: step 13, image 2 of 2
      • De-route the left speaker cable along the top edge of the upper LCD.
      Ask FixBot
    5. Nintendo DSi XL Speakers Replacement: step 14, image 1 of 1
      • Open the display slightly, and lift the LCD out of the front bezel.
      • Lay the LCD down next to the DSi XL.
      • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
      Ask FixBot
    6. Nintendo DSi XL Speakers Replacement: step 15, image 1 of 1
      • Desolder the two solder joints to separate the speakers from the LCD.
      • Right Speaker
      • Left Speaker
      • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
      • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
      Ask FixBot
4 other people completed this guide.
Matthew Newsom
43,003 Reputation
67 Guides authored
4 Guide Comments
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - Reply Share
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - Reply Share
is there anyway of adding two more speaker?
vincent johnson - Reply Share
Awesome guide. Thanks for doing this.
Dandelion - Reply Share
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 143
All Time: 8,413
