Nintendo DSi XL Lower Case Replacement
    1. Nintendo DSi XL Lower Case Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Lower Case Replacement, Battery: step 1, image 2 of 2
      • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
      • Lift the battery cover off the back of the DSi XL.
      Ask FixBot
    2. Nintendo DSi XL Lower Case Replacement: step 2, image 1 of 1
      • Lift the battery from the DSi XL.
      Ask FixBot
    1. Nintendo DSi XL Lower Case Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Lower Case Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Lower Case Replacement, Lower Case: step 3, image 3 of 3
      • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
      Ask FixBot
    2. Nintendo DSi XL Lower Case Replacement: step 4, image 1 of 1
      • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
      • Four silver 5.3 mm screws
      • Two black 5.3 mm screws
      • One black 2.5 mm screw
      Ask FixBot
    3. Nintendo DSi XL Lower Case Replacement: step 5, image 1 of 3 Nintendo DSi XL Lower Case Replacement: step 5, image 2 of 3 Nintendo DSi XL Lower Case Replacement: step 5, image 3 of 3
      • Turn the DSi XL over, and open the display.
      • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
      • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
      Ask FixBot
    4. Nintendo DSi XL Lower Case Replacement: step 6, image 1 of 2 Nintendo DSi XL Lower Case Replacement: step 6, image 2 of 2
      • Close the display and turn the DSi XL over.
      • Lift the lower case from the front edge.
      • Rotate the lower case away from the DSi.
      • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
      Ask FixBot
    5. Nintendo DSi XL Lower Case Replacement: step 7, image 1 of 2 Nintendo DSi XL Lower Case Replacement: step 7, image 2 of 2
      • Using a spudger, pry the SD card/right shoulder button connector off its socket.
      • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
      Ask FixBot
7 other people completed this guide.
David Hodson
156,748 Reputation
127 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 125
All Time: 11,749
